Regular Android build for Rock64?
(08-31-2018, 06:34 PM)kostaman Wrote:
(08-29-2018, 02:52 PM)dudemo Wrote:
(08-26-2018, 08:48 AM)fender90 Wrote: So the question is if there are any plans to release a regular version of Android for this board?
The ROCKPro64 is supposed to be getting a stock version of Android, so perhaps you might want to update to that board? It also has the benefit of long-term support, something that the Rock64 doesn't have and as such will probably be dropped from development soon enough.
I don't believe the Rock64 Development will be totally dropped as LibreELEC OS is being actively tested and developed with Rockchip employees participating. Android and Android TV Development is probably an unknown. Depending on your needs, the RockPro may be overkill when making a purchase decision. I've been using Ayufans' Android TV on my Rock64 eMMC and LibreELEC via SD Card Boot. Suits my needs.
I meant official development by the Rock64 team. I figure third-party development will stick around for a while after the team drops development.
Regular Android build for Rock64? - by fender90 - 08-18-2018, 06:53 AM
RE: Regular Android build for Rock64? - by tllim - 08-24-2018, 03:35 PM
RE: Regular Android build for Rock64? - by Pepe - 11-02-2018, 05:49 PM
RE: Regular Android build for Rock64? - by dudemo - 08-29-2018, 02:52 PM
RE: Regular Android build for Rock64? - by dudemo - 08-31-2018, 07:01 PM
  Android Images (ROCK64) pineadmin 77 223,938 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 11,174 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 11,399 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 9,809 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 7,502 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 6,369 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 5,648 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 9,657 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 4,573 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 7,655 09-18-2020, 07:58 PM
Last Post: BowerR64
