My Rock64 no power or light issue
I assume you tried powering it up without an SD card inserted and got the same result. Sounds like a bad power supply or a bad power connector on the board. Hard to tell. Do you have a meter to test output on power supply and input on the board.
If you had a power supply from an old IP webcam which has the same barrel connector you could try using it to rule out a DOA board. Those IP webcam power supplies are usually 2amp so it would at least boot up the Rock64 if it's working.
Alternatively you could just return the lot to the supplier
My Rock64 no power or light issue - by Nolaboy406 - 07-23-2018, 03:48 PM
RE: My Rock64 no power or light issue - by Rocklobster - 07-23-2018, 07:01 PM
RE: My Rock64 no power or light issue - by t4_4t - 07-23-2018, 07:10 PM
RE: My Rock64 no power or light issue - by Luke - 07-24-2018, 12:52 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 4,905 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 23,519 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 14,441 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 15,497 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 3,824 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 8,286 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 9,492 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 8,613 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,150 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 4,228 10-07-2022, 07:50 PM
Last Post: rookie_267
