Display limited to 800x600 [SOLVED]
(07-06-2018, 08:04 AM)Averell Wrote: Hello,
Question : is it possible to fix the problem in the installed 0.5 version, or is it necessary to start all over from scratch ?
Idea
We have found a workaround :
  1. Install a Community Debian Stretch Minimal, build 0.6.44 on a Micro SD card.
  2. Verify it works correctly, and for this remove first the eMMC, and run on the SD card alone. The display resolution should be OK with a 0.6.x build.
  3. Remove the SD card, install it in a card reader
  4. Restart the Rock 64
  5. mount the partition of the SD card where you can find the right files, for us it was sda6, corresponding to the mmcblk0p6 partition.
  6. Replace all the files of /boot/efi of the Rock64 by the corresponding files found on the SD card :
  • extlinux/extlinux.conf
  • dtb
  • image
  • initrd.img
After a restart, the display is OK
Display limited to 800x600 [SOLVED] - by Averell - 07-06-2018, 08:04 AM
RE: Display limited to 800x600 - by ab1jx - 07-07-2018, 05:16 PM
RE: Display limited to 800x600 - by Averell - 07-09-2018, 10:51 AM
Question [SOLVED] Alpine Linux won't boot rock7 1 5,835 10-22-2019, 04:30 PM
Last Post: rock7
  [solved] Unable to start X Osiander 8 11,577 10-03-2018, 03:54 AM
Last Post: jovval
  If you've messed up your eMMC Card - Solved gregb49 11 16,643 07-11-2018, 02:08 PM
Last Post: gregb49
  Any reason why ntp time is 6 minutes slow (Solved) Rocklobster 1 2,574 05-29-2018, 05:27 AM
Last Post: Rocklobster
  [Solved] Open VPN +Wi-Fi hotspot - Debian S3phi40T 1 2,945 05-01-2018, 05:51 AM
Last Post: S3phi40T
  [PROBLEM SOLVED] Distcc Help cooker 2 4,058 05-01-2018, 05:35 AM
Last Post: cooker
  Im having weird crashes on a new rock64 [solved] Trash_Can_Man 4 6,548 02-06-2018, 04:06 AM
Last Post: a1w.ca
Lightbulb MPP+DRM: low level API for video codecs and display (also 4k UHD+HDR+HLG) mcerveny 0 3,055 01-27-2018, 11:23 AM
Last Post: mcerveny
Information Solved - Resize Root Filesystem (Xenial) aussiemate 4 7,988 08-29-2017, 03:43 PM
Last Post: fbms
