PINE A64+ 4K Media Computer
I was a KS backer for the PINE A64+ 4K Media Computer (with the 2GB upgrade and WiFi/BT add-on).  I received my PINE about two years ago, assembled it, hooked up a monitor, keyboard, and mouse, and fired it up - everything worked just fine!  But, we were about to move, so the PINE got packed (away along with a LOT of other electronics), before I could really play with it.
I recently unpacked the PINE (the move was delayed... a bit), and, with the intention of completely ditching cable TV, told my wife that the 2nd TV would no longer have a cable box, and would use the PINE, instead.  (Her reaction was, "whatever, as long as Netflix, Hulu, and Pandora still work.")  I now have it connected to the TV, with a BT keyboard and mouse combo.  I have an ethernet cable plugged in (the LED is flashing, so it appears to work).  The PINE is also connected to the WiFi (seems that I had to connect to log into my Google Play account?)
This is running off the 8GB Android (v5.1.1?) microSD that came with the PINE.  Should I upgrade to a later version?  It looks like the current v7.0/7.1 builds don't work with Netflix, so should I use Android 6.0?  Other than not longer having an old version of Android (and being unable to install some newer apps), are there other advantages to upgrading to 6.0?  We have a Netflix subscription - could I install 7.0/7.1 and be able to run the app without problem, or are there other issues with the 7.x build that block Netflix?
Finally, what apps would you recommend "to turn this into an advanced Apple TV-like Android product"?
Thanks for your help!
PINE A64+ 4K Media Computer - by RWL - 07-03-2018, 03:32 PM
RE: PINE A64+ 4K Media Computer - by joe - 07-03-2018, 11:12 PM
RE: PINE A64+ 4K Media Computer - by dkryder - 07-04-2018, 05:48 AM
RE: PINE A64+ 4K Media Computer - by Luke - 07-04-2018, 06:42 AM
RE: PINE A64+ 4K Media Computer - by mindwave - 11-08-2018, 04:20 PM
  pine store paulhide 1 3,213 09-17-2020, 04:13 AM
Last Post: bcnaz
Question How to assemble a portable ARM computer. onizou 0 2,171 08-15-2020, 10:30 AM
Last Post: onizou
  My optimal software configuration for pine A64(+) 2Gb Alkemyboy 3 4,651 03-18-2020, 08:41 AM
  Pine HDMI -> DVI monitor Pineapple 4 7,808 09-10-2019, 11:28 AM
Last Post: Pineapple
  Multi Room Audio - Pine style mjgoode 4 8,694 09-19-2018, 10:30 AM
Last Post: mjgoode
  Pine 64 LTS Schematic And R18 Reference Manual Akash Gajjar 2 5,264 12-26-2017, 07:01 PM
  [PINE A64+ 2GB] Ubuntu - Losing Signal Arlanps 4 6,249 02-12-2017, 05:12 PM
Last Post: Arlanps
  Applying a fan for the Pine 64+? Maximum 5 9,561 01-20-2017, 03:34 PM
Last Post: Shad0wSt4R
  Using Pine cluster for Docker Swarm jpnh 1 3,811 11-22-2016, 07:11 AM
Last Post: jpnh
  Pine 64 IR Receiver not working rajatgarg21 1 3,199 08-31-2016, 12:47 AM
Last Post: MarkHaysHarris777
