If you've messed up your eMMC Card - Solved
I did once mess up the eMMC Card on my Odroid XU4. Hardkernel has a eMMC Bootloader Recovery tool that, will recover the boot loader. As they say, the:
Quote:".. boot loader is placed on the Boot Partition(Hidden Partition) in the eMMC memory. .. When it is corrupted or you want to use the eMMC with other different board, you must install the proper boot loader in the eMMC."
  That would have been my next step if all my previous ones had failed, but, of course, that meant taking down two computers instead of just one.
Maybe some clever coder can write one for the Pine boards, or am I the only one to mess up my eMMC card?
PinePhone Beta 2GB/16GB Postmarket OS v23.06.1 Phosh 0.30.0 (not in use)
PineTab2 Arch Danctnix 6.4.2
RE: If you've messed up your eMMC Card - Solved - by gregb49 - 07-04-2018, 07:28 AM
  Buildroot 2021.08 not booting from SD card jimmy 1 2,031 11-08-2021, 02:25 AM
Last Post: hunderteins
  Debian (Vanilla) on Rock64 and eMMC - how ? as365n4 4 5,287 09-21-2020, 04:33 AM
Last Post: as365n4
  Display limited to 800x600 [SOLVED] Averell 16 18,750 06-05-2020, 11:07 PM
Last Post: ab1jx
  Nextcloudpi SD card fills up. default_user8 13 16,786 12-04-2019, 01:30 PM
Last Post: Rocklobster
Question [SOLVED] Alpine Linux won't boot rock7 1 5,782 10-22-2019, 04:30 PM
Last Post: rock7
  Clone the SD to eMMC tagyro 1 3,396 02-06-2019, 06:55 AM
Last Post: evilbunny
  Repair corrupt root filesystem on emmc David82 1 3,754 01-31-2019, 01:11 PM
Last Post: Tozzi
  Migrate Linux from microSD to onboard eMMC elik745i 7 9,880 11-03-2018, 08:23 AM
  [solved] Unable to start X Osiander 8 11,481 10-03-2018, 03:54 AM
Last Post: jovval
  Tutorial How to write a image in the eMMc card without USB adaptor or serial cable gedas07 2 3,840 08-29-2018, 10:08 AM
Last Post: gedas07
