ROCK64 RTC
#20
(02-01-2019, 02:23 PM)KC7NOA Wrote:
(01-31-2019, 06:54 PM)evilbunny Wrote:
(01-31-2019, 12:51 PM)KC7NOA Wrote: trying to overwrite '/usr/lib/aarch64-linux-gnu/libEGL.so', which is also in package libmali-rk-utgard-450-r7p0:arm64 1.6-1ayufan10
Errors were encountered while processing:
/var/cache/apt/archives/libglvnd-dev_1.0.0-2ubuntu2.2_arm64.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
rock64@rock64:~/Downloads/sdrangel/build$
You should be able to use dpkg with --force to make the installer overwrite the file
dpkg --force-help
That does not mean much to me .. the help contents is not helpful when you dont know what to do with the contents
You could try the following, but I haven't tested, which is why I posted the help screen:
sudo dpkg --force-overwrite -i /var/cache/apt/archives/libglvnd-dev_1.0.0-2ubuntu2.2_arm64.deb
ROCK64 RTC - by Avengerman14s - 06-09-2018, 05:36 PM
RE: ROCK64 RTC - by MichaelRock - 06-10-2018, 01:41 AM
RE: ROCK64 RTC - by pfeerick - 06-10-2018, 02:26 AM
RE: ROCK64 RTC - by MichaelRock - 06-10-2018, 04:34 AM
RE: ROCK64 RTC - by petec - 06-10-2018, 01:05 PM
RE: ROCK64 RTC - by dcdc138813 - 07-29-2018, 08:20 PM
RE: ROCK64 RTC - by tllim - 08-02-2018, 10:35 PM
RE: ROCK64 RTC - by dcdc138813 - 08-03-2018, 12:33 AM
RE: ROCK64 RTC - by petec - 08-06-2018, 03:01 PM
RE: ROCK64 RTC - by petec - 10-28-2018, 07:02 AM
RE: ROCK64 RTC - by turkerali - 11-21-2018, 01:08 PM
RE: ROCK64 RTC - by petec - 11-23-2018, 02:44 PM
RE: ROCK64 RTC - by KC7NOA - 01-29-2019, 08:59 AM
RE: ROCK64 RTC - by evilbunny - 01-29-2019, 03:29 PM
RE: ROCK64 RTC - by KC7NOA - 01-30-2019, 09:50 AM
RE: ROCK64 RTC - by evilbunny - 01-30-2019, 04:22 PM
RE: ROCK64 RTC - by KC7NOA - 01-31-2019, 12:51 PM
RE: ROCK64 RTC - by evilbunny - 01-31-2019, 06:54 PM
RE: ROCK64 RTC - by KC7NOA - 02-01-2019, 02:23 PM
RE: ROCK64 RTC - by evilbunny - 02-01-2019, 04:03 PM
RE: ROCK64 RTC - by KC7NOA - 02-01-2019, 04:41 PM
RE: ROCK64 RTC - by petec - 02-08-2019, 07:17 AM
RE: ROCK64 RTC - by tllim - 02-10-2019, 11:39 PM
RE: ROCK64 RTC - by waqasnasir - 02-11-2019, 11:36 AM
RE: ROCK64 RTC - by tllim - 02-18-2019, 01:59 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 299 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,379 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,713 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,185 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 345 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,912 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,545 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,122 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 766 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 964 10-07-2022, 07:50 PM
Last Post: rookie_267
