pineA64 wifi module.
(05-01-2018, 11:52 PM)Shubhendra Wrote: i am going to buy ROCK64 4GB & i dont know that WiFi module of Pine64 will work or not with rock64. so, tell me Wifi & Bluetooth module of pine64 will work with rock64 or not....
When you look at the pine64 store, there are three wifi/bluetooth modules listed against the rock64: I can't comment as to the top two, but I have recently purchased the third one, and it just worked with a pine64 running Armbian, but not on the rock64 when running an older version of ayufan's xenial-container build. That reference to older build is important though, as there is been a recent update that says it enabled support for adapters like the AC one, so it means the ayufan images should now also work with this adapter. I would have thought the other wifi adapter was fine also, but there has been at least one complaint about it of late, so I'll leave that for someone else to chip in and comment on their experiences. There is also the specific pine64 wifi/bluetooth adapter, but you don't want that, as it is specifically for the pine64, so won't plug into the rock64, etc.
pineA64 wifi module. - by Shubhendra - 05-01-2018, 11:52 PM
RE: pineA64 wifi module. - by pfeerick - 05-02-2018, 12:03 AM
RE: pineA64 wifi module. - by S3phi40T - 05-06-2018, 09:40 AM
  Wrong resolution and very slow start of wifi. jgpacc 2 3,774 01-11-2022, 03:55 AM
Last Post: alanwake82
  Rock64 running OMV, how to setup RTL8812AU WiFi? electrosam 3 4,962 02-21-2020, 01:49 AM
Last Post: bigtreeman
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 105,424 02-06-2019, 04:02 PM
  Rock64 Compute Module ktc 5 7,651 08-24-2018, 03:23 PM
  Compatible WiFi modules for Rock64 j3eeenet 8 13,342 08-08-2018, 02:06 AM
Last Post: AnythingIsFine
  ROCK64 does not recognize USB Wifi module (WL300NU-G) pine3228 2 4,145 01-03-2018, 03:56 AM
Last Post: pine3228
  RTC module? mbc28 7 8,450 11-14-2017, 10:23 PM
  USB WiFi/BT dongle gas14 9 10,436 10-24-2017, 01:31 AM
Last Post: gas14
  Monitor Rock64 serial console with PineA64 MarkHaysHarris777 7 15,638 09-09-2017, 04:35 PM
Last Post: MarkHaysHarris777
  Would a module form factor be possible? liqdfire 3 4,008 07-12-2017, 06:31 PM
