RTC module?
Is there any plan to support RTC on the Rock64 board? Will there be any extra RTC module?
(09-04-2017, 03:02 PM)mbc28 Wrote: Hello,
The RTC module locate at the ROCK64 PMU chip. We plan to add RTC battery support on next board revision.
Great! Do you have any estimated date for the next board version?
(09-07-2017, 02:32 AM)mbc28 Wrote: Great! Do you have any estimated date for the next board version?
December 2017, add in RTC Battery option is the only revised item.
could we  add ourself with soldering iron for current version
Attached is the schematic is you interest to try out. However, it is not an easy task due to power plane involved.
when will this board version with added RTC battery support become available for purchase ?
Any more specific date ?
(11-13-2017, 01:51 PM)jgreg Wrote: Hello,
due to currently production timing, we have not factor in the RTC circuit into current production batch and will check with engineering team when able to factor in.
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 181,589 02-06-2019, 04:02 PM
  Rock64 Compute Module ktc 5 12,190 08-24-2018, 03:23 PM
  pineA64 wifi module. Shubhendra 2 6,204 05-06-2018, 09:40 AM
Last Post: S3phi40T
  ROCK64 does not recognize USB Wifi module (WL300NU-G) pine3228 2 6,614 01-03-2018, 03:56 AM
Last Post: pine3228
  Would a module form factor be possible? liqdfire 3 6,840 07-12-2017, 06:31 PM
