Has the Pine worked with your HDMI display?
Everything I hooked it to worked!
26.42%
14
Some screens/cables worked for me.
33.96%
18
Nothing has worked so far.
39.62%
21
53 vote(s)
HDMI issues
#22
(06-19-2016, 01:32 PM)phloog Wrote: I'm beginning to think that the three or four most passionate and geeky owners of this thing should keep playing, and the other 99% of the people who backed this should just put it in a closet for a while, then when it's actually working close to properly they can send out an email to everyone.
I have tried FOUR monitors now (two different Samsung, two other brands), using a different HDMI cable each time, with two difference lengths of HDMI cable.
EVERY monitor tells me that I have an "Unsupported Resolution"....
I have tried three different OS (including Remix, which I thought was the one in best shape)..no change..no video.
Tell me how exactly I troubleshoot an issue with no video?
Try the two OS writing tools and images I posted in the thread you started, here.
Work through systematically, one monitor at a time, one hdmi cable at a time. Do not use any hdmi splitters, use a direct hdmi connection. You got the PSU provided by Pine, and quite rightly have baulked at that possibly being the issue, reasoning that the supplied PSU should work with the board, which seems like logical reasoning (though the microSD cards supplied by Pine have been criticised as being fairly poor - I can't recall if you mentioned which microSD card you are using. That could be a factor as well).
On the face of it, 'unsupported resolution' would suggest that the monitors you are trying do not support either 720p or 1080p, which are the only two resolutions that the Pine64 works with at the moment (not including the 1024 x 600 image used for the LCD touchscreen). But I know from your other posts that at least one of your monitors does support 1080p, as it appears as the resolution setting on your screen, just that you are not getting a picture to go with it.
You are right, though. It shouldn't be this problematic to get everything set up.
HDMI issues - by rahlquist - 04-05-2016, 11:25 AM
RE: HDMI issues - by indigokid - 04-05-2016, 12:17 PM
HDMI issues - by s21 - 04-05-2016, 02:47 PM
RE: HDMI issues - by MichaelMeissner - 04-05-2016, 04:09 PM
RE: HDMI issues - by rahlquist - 04-06-2016, 08:52 AM
RE: HDMI issues - by Tarjei85 - 04-06-2016, 01:14 PM
RE: HDMI issues - by MichaelMeissner - 04-06-2016, 12:11 PM
RE: HDMI issues - by rahlquist - 04-06-2016, 12:46 PM
RE: HDMI issues - by perillamint - 04-07-2016, 06:59 AM
RE: HDMI issues - by pine.tree - 04-07-2016, 10:42 AM
RE: HDMI issues - by LinuxGeek - 04-07-2016, 12:43 PM
RE: HDMI issues - by Drey - 04-07-2016, 02:02 PM
RE: HDMI issues - by DaveyDarko - 04-07-2016, 02:39 PM
RE: HDMI issues - by brf - 05-22-2016, 01:27 PM
RE: HDMI issues - by tankie64 - 06-04-2016, 09:11 PM
RE: HDMI issues - by CaptainZalo - 06-04-2016, 11:04 PM
RE: HDMI issues - by tankie64 - 06-05-2016, 06:23 AM
RE: HDMI issues - by pine.tree - 06-06-2016, 07:03 AM
RE: HDMI issues - by aegrotatio - 06-07-2016, 10:58 PM
RE: HDMI issues - by gwizard - 06-08-2016, 08:06 PM
RE: HDMI issues - by phloog - 06-19-2016, 01:32 PM
RE: HDMI issues - by Ghost - 06-19-2016, 04:36 PM
RE: HDMI issues - by 3lliot - 06-21-2016, 04:04 PM
RE: HDMI issues - by xalius - 06-21-2016, 04:21 PM
RE: HDMI issues - by dhardingham - 06-22-2016, 02:21 AM
RE: HDMI issues - by 3lliot - 06-22-2016, 04:40 AM
RE: HDMI issues - by longsleep - 06-22-2016, 10:43 AM
RE: HDMI issues - by 3lliot - 06-21-2016, 07:04 PM
RE: HDMI issues - by Shad0wSt4R - 06-21-2016, 09:18 PM
RE: HDMI issues - by lenny.raposo-pine64.pro - 06-22-2016, 07:48 AM
RE: HDMI issues - by 3lliot - 06-22-2016, 01:54 PM
RE: HDMI issues - by sboyce - 07-10-2016, 09:42 AM
RE: HDMI issues - by kthomsen - 07-11-2016, 12:07 PM
RE: HDMI issues - by sboyce - 07-12-2016, 03:37 PM
RE: HDMI issues - by JTRiker9 - 12-23-2016, 08:44 PM
RE: HDMI issues - by sboyce - 12-24-2016, 02:20 AM
Sad HDMI to DVI Color issues? leatherlips 5 15,331 10-09-2017, 05:57 AM
Last Post: Luke
  Would HDMI screen for Raspberry PI work? dhewko 1 3,483 07-23-2017, 06:43 AM
Last Post: MarkHaysHarris777
Exclamation HDMI 1024 x 600 mus1c 4 6,295 01-09-2017, 07:30 AM
Last Post: mus1c
  HDMI-DVI aminhb 11 17,692 01-08-2017, 10:52 AM
Last Post: Luke
  Monitor no output (through HDMI to DVI adaptor) gam01hr 10 15,007 11-15-2016, 01:46 PM
Last Post: Armbian User
  HDMI CEC ayufan 15 19,771 09-08-2016, 10:24 AM
Last Post: ayufan
  HDMI to VGA adapter for Android PineA64 tech support setup MarkHaysHarris777 0 2,420 08-06-2016, 12:47 PM
  hdmi_group CEA or DMT hdmi group specify uEnv.txt MarkHaysHarris777 2 5,036 07-01-2016, 08:23 AM
  No CEC over HDMI? utdrmac 2 5,687 03-07-2016, 03:05 PM
Last Post: utdrmac
  HDMI 3D, ARC + Ethernet Channels? bigmacattack 4 12,092 01-29-2016, 06:29 PM
Last Post: StefanB
