4K @ 60Hz (2160p60) distro support?
(02-21-2018, 04:44 PM)mcerveny Wrote: Not exactly true. Now you can decode and display in 60FPS (of cause in YUV420, TMDS Clk: 297MHz) and after resolving some problems HDR/HLG (of cause in YUV420-10bit, TMDS Clk: 371MHz). Rock64 is capable of sending "frame metadata" to support static HDR (HDMI2.0a) and HLG (HDMI2.0b).
Yes, you are correct.  I realize I'm in a small minority that would want to use this for text rather than full-motion video.  There's no doubt the RK3328 is designed & marketed for Android STB.
YUV420-10bit feels silly though - lets take away 75% of the color information out of the frame, then increase the depth 25%.... Any 10-bit 4K panel that supports HDR10 or Dolby Vision (that I've ever seen) supports all the HDMI 2.0 resolutions (TMDS 594MHz).  I have seen cheaper UHDTVs that support HDR10, but only have 8-bit panels, but those are also silly in my opinion.
RE: 4K @ 60Hz (2160p60) distro support? - by spawnflagger - 02-22-2018, 12:02 PM
  1024x600 resolution support monte 1 2,829 03-14-2021, 11:32 PM
Last Post: monte
  Encryption support rockfun 1 2,985 06-10-2020, 08:27 AM
Last Post: rockfun
  mainline kernel sound support Openwrt lucize 2 4,131 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 7,218 04-18-2020, 11:34 PM
Last Post: CameronNemo
  MSI-X support for KVM? pfworks 1 3,705 06-12-2019, 03:48 AM
Last Post: RussianNeuroMancer
  Hyperion/Ambilight support? qwasy 5 7,861 03-30-2019, 04:40 PM
Last Post: antaril
  Arch Linux minimal image w/ full HDMI output support hiccupstix 1 3,698 11-01-2018, 08:33 AM
Last Post: danboid
  Most stable Linux rom and 1080p support? Nelly 2 4,173 10-08-2018, 12:30 PM
Last Post: Nelly
  Updates on Mainline Linux Support? hnaguski 0 2,506 09-11-2018, 08:16 PM
Last Post: hnaguski
  Kodi + Docker - what are the image options for Rock64 to support this? zarusz 0 2,653 05-20-2018, 01:41 AM
Last Post: zarusz
