Stable OS for Pine?
Okay, so here's an update...
I bought a 32gb class 10 micro sd card to see if that was the problem (my other card was a 8gb class 6)... It wasn't. The card is legit as was the previous card, no counterfeit problems. So that wasn't that either.
I'm still powering the board from my external usb hub and it seems to do fine. I have a keyboard/mouse controller dongle plugged into the hub and it works perfect. I am using ethernet as I have no wifi and that seems to work as well. I am running Lollipop.
I successfully downloaded Netflix and Youtube apps from the Google Appstore with no problem. Video and audio is flawless in both. However, I notice when I install a new app and open it, it seems to freeze. I then had to go out of each app and back in for it to refresh. I have no idea what's causing this. I also noticed this in OS itself. I know this sounds crazy but running an app or changing a setting and then turning the machine off and re-running it seems to fix a lot of issues.
Chrome seems super buggy. Youtube will play in Chrome but if I fullscreen it, it crashes, android restarts and I have no ethernet. I have to physically turn the machine off and back on for it to recognize ethernet.
Sometimes when I try and change the wallpaper I get a screen flicker. Sometimes the screen goes black. Sometimes I get a message saying "Unfortunately, Launcher3 has stopped." Again, I have no clue.
At this point, there are just tons and tons of bugs.
Stable OS for Pine? - by franktherobot - 04-05-2016, 06:59 AM
RE: Stable OS for Pine? - by Andrew2 - 04-05-2016, 07:35 AM
RE: Stable OS for Pine? - by franktherobot - 04-05-2016, 07:42 AM
RE: Stable OS for Pine? - by Andrew2 - 04-05-2016, 07:55 AM
RE: Stable OS for Pine? - by franktherobot - 04-05-2016, 09:16 AM
RE: Stable OS for Pine? - by Andrew2 - 04-05-2016, 09:52 AM
RE: Stable OS for Pine? - by franktherobot - 04-05-2016, 11:07 AM
RE: Stable OS for Pine? - by franktherobot - 04-05-2016, 07:15 PM
RE: Stable OS for Pine? - by Harrisburg - 04-06-2016, 02:47 PM
RE: Stable OS for Pine? - by Kevydee - 04-06-2016, 07:49 PM
RE: Stable OS for Pine? - by connorja - 04-07-2016, 01:30 PM
RE: Stable OS for Pine? - by Harrisburg - 04-08-2016, 11:57 AM
RE: Stable OS for Pine? - by hukuzatuna - 04-12-2016, 11:42 AM
  pine store paulhide 1 3,239 09-17-2020, 04:13 AM
Last Post: bcnaz
  My optimal software configuration for pine A64(+) 2Gb Alkemyboy 3 4,684 03-18-2020, 08:41 AM
  Pine HDMI -> DVI monitor Pineapple 4 7,870 09-10-2019, 11:28 AM
Last Post: Pineapple
  PINE A64+ 4K Media Computer RWL 4 6,930 11-08-2018, 04:20 PM
Last Post: mindwave
  Multi Room Audio - Pine style mjgoode 4 8,738 09-19-2018, 10:30 AM
Last Post: mjgoode
  Pine 64 LTS Schematic And R18 Reference Manual Akash Gajjar 2 5,297 12-26-2017, 07:01 PM
  [PINE A64+ 2GB] Ubuntu - Losing Signal Arlanps 4 6,280 02-12-2017, 05:12 PM
Last Post: Arlanps
  Applying a fan for the Pine 64+? Maximum 5 9,602 01-20-2017, 03:34 PM
Last Post: Shad0wSt4R
  Using Pine cluster for Docker Swarm jpnh 1 3,838 11-22-2016, 07:11 AM
Last Post: jpnh
  Pine 64 IR Receiver not working rajatgarg21 1 3,222 08-31-2016, 12:47 AM
Last Post: MarkHaysHarris777
