unreliable serial console output?!
(10-14-2017, 11:01 AM)consoleadam Wrote:
(10-14-2017, 09:36 AM)MarkHaysHarris777 Wrote: hi,
Please describe your topology;  also, which usb to serial TTL bridge adapter are you using ( which model, chipset ) ?
As stated, the usb to serial TTL bridge adapter is the one listed on Pine64 site:
https://www.pine64.org/?product=padi-serial-console
hi ,  when I asked for your topology I meant that I want to know how 'specifically' you have it wired.
The chipset I believe you are using is the CH340g;  this is the best adapter we can recommend and it is reliable, but because of the higher frequencies (1.5M baud rate) the topology is more critical; hap-hazzard wiring will not work well.  Here are some tips:
1) DO NOT connect the voltage lead of the CH340g adapter ANYWHERE...  ( words to the wise )
2) make sure you have a good ground connection
3) place the adapter CH340g as close to the Rock64 as possible ( no more than 6" leads, but the shorter the better )
4) use three wires:  Tx,  Rx,  Ground
5) use a 'short' usb extension cable from the adapter to the monitor computer.
6) use minicom with gnu+linux   ( any distro )
7) use the settings and disable both flow controls ( hardware and software )
If still unstable or unreliable, try plugging the CH340g into a powered hub.  Plug the powered usb hub into the monitor computer, then plug the CH340g into the powered hub.  Often the CH340g will not work well at higher baud rates on all ports unless it gets better power feed;  this is particularly true if you're trying to use the Pinebook left hand usb port !  Any powered usb hub ( Belkin's is nice ) will work;  however, make sure that your powered hub does not provide back-feed -- do your research.
Also not all usb ports are identical;  some have internal hubs ( which work better for terminals ).  For instance the Pinebook's right hand usb port is a hub, and it works brilliantly with the CH340g no worries.
Shy
PS,  if you have another SBC ( Rapsberry PI, PineA64+, etc ) you can use that SBC uart directly ( no adapter ) to monitor the Rock64 serial console output !
RE: unreliable serial console output?! - by MarkHaysHarris777 - 10-14-2017, 01:00 PM
RE: unreliable serial console output?! - by maal - 10-14-2017, 12:40 PM
  Rock64 <--> Rock64 Serial Connection mark1250 1 2,071 12-23-2021, 09:27 PM
Last Post: barray
Information Serial Console for the Rock64 MarkHaysHarris777 33 63,275 06-24-2021, 12:24 PM
Last Post: mikeklien
Big Grin Rock64 as a retro-gaming console: early impressions Luke 54 105,318 10-07-2020, 11:21 AM
Last Post: jakejm79
Sad No boot, garbage console text and blinking red light ... jean_bruder 2 3,967 07-19-2020, 08:37 AM
Last Post: jean_bruder
  Rock64 as a retro-gaming console: personal thoughts Danielsan 8 11,834 09-13-2018, 03:45 PM
Last Post: jessiehughes
Sad Rock64 2GB Version Can't output 4K Signal leonqin 1 2,625 08-18-2018, 05:59 PM
Last Post: leonqin
  ROCK64 uboot HDMI no signal output LemonZou 2 4,191 10-17-2017, 02:15 AM
Last Post: dkryder
  Newbie question - should a Rock64 with no mmc card still output some video ? sgk 6 8,146 10-14-2017, 08:16 PM
Last Post: fusionneur
  Monitor Rock64 serial console with PineA64 MarkHaysHarris777 7 15,701 09-09-2017, 04:35 PM
Last Post: MarkHaysHarris777
