Ethernet --> Causing boot loop
Anyone else with the 2GB module experiencing issues with an endless boot loop whenever Ethernet is plugged in.  I am using a 5v 2amp DC power supply and everything works fine until I plug in ethernet.  I also tried Remix OS / Android Lollipop with the exact same symptoms.  Any help is appreciated as I would be disappointed if I am unable to use the full potential of the board Smile
Ethernet --> Causing boot loop - by podtofs - 03-31-2016, 02:10 PM
RE: Ethernet --> Causing boot loop - by pine.tree - 03-31-2016, 03:31 PM
RE: Ethernet --> Causing boot loop - by S4BRE - 04-01-2016, 11:31 PM
RE: Ethernet --> Causing boot loop - by m17 - 05-16-2017, 03:41 AM
  Ethernet port down afert 1 day jeda 0 645 11-12-2022, 06:48 AM
Last Post: jeda
  Boot needs up to 7 minutes on Ubuntu 16.04 JulianM 3 5,592 03-15-2017, 05:46 AM
Last Post: pfeerick
  GbE Ethernet Port Issue Data Gathering Statistics Intel MarkHaysHarris777 19 24,601 01-17-2017, 01:17 AM
Last Post: DrunkTank
  What will it take to get the Ethernet port working? clarkss12 10 16,518 10-17-2016, 03:42 PM
Last Post: waldo
  Ethernet Slow Download Ascotg 89 113,857 09-08-2016, 01:50 PM
Last Post: MarkHaysHarris777
  Pine64+ 1GB Ethernet Port spec ecotack 13 15,770 08-20-2016, 09:28 PM
Last Post: pfeerick
  If you have had difficulty with the GbE ethernet please take the poll MarkHaysHarris777 0 2,390 08-17-2016, 05:44 PM
  Ethernet works on Arch Linux. Nothing elese pfunk237 4 6,143 07-23-2016, 03:07 PM
Last Post: SuperArmySoldiers
