linux boot error
(09-05-2017, 08:32 AM)jerson Wrote: i cant boot with linux in rock64, i just format with pine installer, im using toshiba exceria 16gb, android works but linux dont   Huh
You need to provide ayufan with the boot log captured with another computer connected to the Rock64 as described in the forum Hardware & Accessories category. The photos you sent aren't adequate. See:
"How to Setup Serial Console Cable Over the Rock64 SBC"
In minicom you will need to capture boot data into minicom.cap file.
Once in minicom, use Cntrl-A Z, then select L to:
        Turn Capture file on off. If turned on, all output sent to the screen will be captured in the file too.
In Ubuntu (Linux), the minicom.cap file should appear in your user home directory.
Send the minicom.cap file to ayufan.
Hope this helps.
linux boot error - by jerson - 09-05-2017, 08:32 AM
RE: linux boot error - by moravecz - 09-05-2017, 08:48 PM
RE: linux boot error - by epikhinm - 10-16-2017, 01:02 PM
RE: linux boot error - by dkryder - 10-17-2017, 01:23 AM
RE: linux boot error - by Luke - 10-17-2017, 02:49 AM
RE: linux boot error - by JoeH - 11-16-2017, 12:14 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 158 03-24-2024, 01:07 PM
  Rock64 won't boot dstallmo 0 345 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 603 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,761 06-02-2023, 07:52 AM
Last Post: diederik
  Disabling last mount time check on boot acwest 0 634 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,821 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,055 06-27-2022, 06:52 PM
  Linux 5.15 Kernel - openSuse mark1250 0 1,299 12-02-2021, 04:36 PM
Last Post: mark1250
  Alpine Linux isndw 12 17,941 08-12-2021, 05:41 PM
Last Post: pix
Lightbulb RK3399 Linux rtl8822cu module bluetooth not working shivarj89 0 1,363 07-29-2021, 07:19 AM
Last Post: shivarj89
