Beginners Guide: Locating your board, connecting to it.
Connecting to your board via SSH
How you connect via SSH depends on what OS you are using as a client (the device you want to SSH From). The server in this case is the Rock 64 Board.
The username/password of the Rock64 OS will depend on which OS you've downloaded and flashed:
http://wiki.pine64.org/index.php/ROCK64_Main_Page
Windows:
If you use Windows, it doesnt have an SSH client, you'll need to download one to SSH into the Rock 64.
Here is one example:
https://www.fastcomet.com/tutorials/gett...rted/putty
However, for step 2, you'll need to insert the IP address of the Rock 64 ou found in the previous post: In this example it was 192.168.1.128. Yours will likely be different.
You should have it looking somewhat similar to this:
[Image: FSWVGgq.png]
Click on "Open" to start initiating a SSH connection. You might get a warning message about a RSA key.
[Image: qIsxH4l.png]
Its not important at this stage, since it is over a local connection and you have physical access to the hardware. Accept the connection.
Once you accept the connection, you'll be prompted to insert a Username/Password. This depends on the OS image you downloaded, its available on the Wiki Link. In My case, the image is the "Xenial Mate" image, so the username/password is rock64/rock64. Its normal to not see the password being typed in, this is a security feature.
[Image: QRrKPof.png]
If everything goes well, you should now be logged into your Board, and the display should look something like this:
[Image: u9ukGUz.png]
That means you're in and you can issue commands and communicate with your board via SSH!
Mac OS:
I dont have a Mac OS device to test this out on, but the process is much more simpler on Mac OS and Linux than windows.
http://osxdaily.com/2017/04/28/howto-ssh-client-mac/
In this scenario, the string:
ssh username@ip.address
Would look like
ssh rock64@192.168.1.128
Again, this depends on which Image was downloaded and what the IP address is.
Linux:
Very similar to the MacOs guide. Open your favourite terminal emulator installed in your distro and enter the credentials and thats all there is to it!
https://help.ubuntu.com/community/SSH/Op...nnectingTo
Connecting to your board via SSH - by Ptheven - 08-08-2017, 05:17 AM
Setting up a Hostname - by Ptheven - 08-08-2017, 06:53 AM
  Beginners Guide: Migrating to SSD rontant 18 60,897 01-19-2022, 09:30 AM
Last Post: Ellesar Dragon
Information Beginners Guide: Adding USB Storage, Linux Formatting and Permissions Ptheven 4 16,187 03-06-2021, 01:49 PM
Last Post: helpmerock
  Step by step guide PXE diskless configuration. burglar_ot 13 45,399 11-01-2020, 11:26 PM
Last Post: michael.gruner
Thumbs Up A guide for how I made RetroPie, RetroArch, and EmulationStation Work on the Rock64 Mrfixit2001 4 20,329 12-17-2018, 03:52 AM
Last Post: va88
  Guide - XRDP - Debian Stretch / Ubuntu Xenial / OMV S3phi40T 3 16,584 05-05-2018, 06:08 AM
Last Post: S3phi40T
Information Guide - Raid Array (Raid 0) Ptheven 0 6,320 10-07-2017, 09:22 AM
Last Post: Ptheven
Information Guide - Setting up a NFS Share Ptheven 0 7,124 09-26-2017, 04:44 AM
Last Post: Ptheven
  Guide - Setting up a SMB(Windows) file server Ptheven 0 14,632 08-21-2017, 08:54 AM
Last Post: Ptheven
