Armbian - Xenial Desktop (Pinebook)
#69
(12-14-2018, 04:24 AM)igorp Wrote: Both versions must/should work.
I didn't test eMMC for this latest build for 1080p with legacy kernel 3.10.y and which is a bit pointless to invest into. Others were tested many times and install is super easy. It is possible that eMMC which is in your Pinebook is not supported in the kernel. It is rare but possible.
Isn't Legacy using the same BSP kernel as the shipped KDE Neon?
You are right though. I don't see the eMMC listed with fdisk -l
Although that appears to be the issue, I don't see why that would make the whole installation section of armbian-config go missing.
I kind of wanted to dump the legacy Ambian onto the eMMC to replace KDE Neon which is useless to me, and continue to run Armbian mainline from MicroSD. This is solely because the legacy release supports BT and appears to support suspend. Besides that it's a pain because it doesn't support the newer version of ext4.
RE: Armbian - Xenial Desktop (Pinebook) - by Luke - 11-11-2017, 08:15 AM
RE: Armbian - Xenial Desktop (Pinebook) - by Luke - 02-25-2018, 09:50 AM
RE: Armbian - Xenial Desktop (Pinebook) - by Luke - 02-26-2018, 01:53 PM
RE: Armbian - Xenial Desktop (Pinebook) - by Luke - 08-10-2018, 04:54 PM
RE: Armbian - Xenial Desktop (Pinebook) - by Luke - 12-10-2018, 02:27 PM
RE: Armbian - Xenial Desktop (Pinebook) - by Luke - 12-13-2018, 02:30 PM
RE: Armbian - Xenial Desktop (Pinebook) - by ImmortanJoe - 12-14-2018, 05:12 AM
RE: Armbian - Xenial Desktop (Pinebook) - by WZ9V - 01-08-2019, 08:07 PM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 2 899 05-26-2025, 11:01 AM
  Armbian broken sometime in the last few months acruhl 4 2,249 05-29-2024, 10:44 PM
Last Post: acruhl
  DietPi OS for Pinebook MichaIng 3 9,031 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 80,138 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 2,403 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 1,759 07-10-2023, 07:44 AM
  Change console resolution (Armbian/bookworm) jcgraybill 1 3,085 06-22-2023, 01:31 PM
Last Post: jcgraybill
  Pinebook no longer boots rjtanner 12 8,311 04-13-2023, 01:09 PM
  Armbian 22.02 Release Announcement TRS-80 0 2,128 02-28-2022, 05:02 PM
Last Post: TRS-80
  Stock Debian on original Pinebook moonwalkers 1 4,470 01-29-2022, 10:37 PM
Last Post: cel
