Pinebook 14" keyboard misses keypresses UPDATE
The replacement keyboard modules present a possible danger to the LCD panel,  because of the larger key-travel;  the keys stand up higher and might therefore bump into the LCD panel when the lid is closed;  although, the LCD panel face is recessed into the top bezel and mostly protected.
Possible damage to the LCD panel face can be mitigated by using self-adhesive silicone bumper pads;  the ones shown in the pic above are 10mm across and 2mm in thickness.  The bumper pads are transparent, and hold the case open just enough that the clearance between the keyboard key-tops and the LCD panel face is more than sufficient.
Pictured above are the installed silicone pads standing in the gap!  This gap serves two purposes:  1) protecting the LCD panel face, and 2) facilitating opening the Pinebook!   Some of you may have noticed that opening the Pinebook is difficult due to the thin front lip;  the silicone bumper pads mitigate this annoyance as well.
In the pic above the silicone pads are shown with the unit open;  the clear bumpers are virtually invisible (mostly attractive) and out of the way;  the pads come in a variety of sizes, and colors;  I found them in black, and also in felt!
Shy
RE: Pinebook 14" keyboard misses keypresses UPDATE - by MarkHaysHarris777 - 09-16-2017, 12:13 PM
  pinebook 1080p power/barrel connector/cable cel 0 561 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,394 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,251 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,669 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,397 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,649 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,652 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,984 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,698 08-20-2020, 08:18 AM
Last Post: Reinoud
  Did pine64 change the keyboard? Hsingai 1 3,878 08-10-2020, 06:52 PM
