Rock64 vs pine64
(07-09-2017, 05:26 AM)joe Wrote:
(07-07-2017, 10:26 AM)fire219 Wrote: While running Android, you're probably not going to notice much of a difference. Everything is going to work basically the same, maybe just a bit smoother. The biggest difference you may notice is that it is more capable of playing 4K video than the Pine64.
Because Rockchip support many video than Allwinner ?
It doesn't really support any more video types (though there is one), but it has better resolution options.
The differences are:
H.264 at 4k@60fps (A64 is limited to 1080@60)
H.265 at 4k@60 (A64: 4k@30)
VP9 at 4k@60 (A64 does not support VP9 at all)
VC-1 at 1080@60 (A64: 1080@30)
So what I meant is that while the A64 technically can play 4k video, it has to be H.265 format, which severely limits the content you can play. The Rock64 does not have this limitation.
Rock64 vs pine64 - by advait - 07-07-2017, 02:14 AM
RE: Rock64 vs pine64 - by wappi - 07-07-2017, 02:33 AM
RE: Rock64 vs pine64 - by fire219 - 07-07-2017, 10:26 AM
RE: Rock64 vs pine64 - by joe - 07-09-2017, 05:26 AM
RE: Rock64 vs pine64 - by fire219 - 07-09-2017, 06:19 AM
RE: Rock64 vs pine64 - by advait - 07-09-2017, 07:34 AM
RE: Rock64 vs pine64 - by Wizzard - 07-11-2017, 05:17 AM
RE: Rock64 vs pine64 - by MarkHaysHarris777 - 07-11-2017, 05:22 AM
RE: Rock64 vs pine64 - by advait - 07-11-2017, 09:30 AM
RE: Rock64 vs pine64 - by MarkHaysHarris777 - 07-11-2017, 11:00 AM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,356 08-04-2021, 07:35 PM
Last Post: Rocklobster
  Android Images (ROCK64) pineadmin 73 169,191 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,049 03-12-2021, 01:38 PM
Last Post: Wizzard
  Android on Rock64 SD Problem ElBoluTony 3 6,079 10-07-2020, 12:10 PM
Last Post: ElBoluTony
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,766 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,885 09-09-2020, 08:44 AM
Last Post: BowerR64
Question Regular Android build for Rock64? fender90 18 26,529 09-09-2020, 08:04 AM
Last Post: BowerR64
  Minimum requirements for ROCK64 Android install? eugenev13 0 2,744 06-04-2020, 02:23 AM
Last Post: eugenev13
  Android 10 for Rock64? Blinky 0 3,714 04-21-2020, 12:55 AM
Last Post: Blinky
  port Rock64 to Lineage OS? noob 10 19,427 04-11-2020, 04:00 PM
Last Post: Pepe
