New Pinebook 14'' does not boot from sd card
(07-04-2017, 06:36 AM)Wizzard Wrote: Can you please benvhmark that samsung evo card using hdparm -t?
Samsung EVO 32GB, with no changes to performance governor, etc, on 11" pinebook, Linux pinebook 3.10.105-bsp-1.2-ayufan-65 #1 SMP PREEMPT Mon Jun 5 06:57:47 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
sudo hdparm -t /dev/mmcblk1
/dev/mmcblk1:
Timing buffered disk reads:  62 MB in  3.03 seconds =  20.45 MB/sec
sudo iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
    Run began: Wed Jul  5 03:34:10 2017
    Include fsync in write timing
    O_DIRECT feature enabled
    Auto Mode
    File size set to 102400 kB
    Record Size 4 kB
    Record Size 16 kB
    Record Size 512 kB
    Record Size 1024 kB
    Record Size 16384 kB
    Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
    Output is in kBytes/sec
    Time Resolution = 0.000001 seconds.
    Processor cache size set to 1024 kBytes.
    Processor cache line size set to 32 bytes.
    File stride size set to 17 * record size.
                                                             random    random     bkwd    record    stride
             kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
         102400       4     1119     1820     5943     5938     5940     1825
         102400      16     8114     5833    13488    13518    13494     5277
         102400     512    16983    17567    22884    22952    22932    17597
         102400    1024    16687    16138    22813    22908    22909    17406
         102400   16384    17214    17546    22695    22765    22806    17541
(07-04-2017, 02:59 PM)tozsoferguson Wrote: My problem has solved. My 128gb Samsung sdxc replaced to an Sandisc 16gb sdhc and it works well.
Glad you got it working! Wink
RE: New Pinebook 14'' does not boot from sd card - by pfeerick - 07-04-2017, 09:47 PM
  pinebook 1080p power/barrel connector/cable cel 0 554 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,389 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,241 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,654 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,367 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,632 09-25-2021, 12:03 AM
  SD card read/write troubles jezek 1 3,010 03-26-2021, 09:27 AM
Last Post: jezek
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,641 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,908 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,689 08-20-2020, 08:18 AM
Last Post: Reinoud
