New Pinebook 14'' does not boot from sd card
(07-03-2017, 01:39 PM)tozsoferguson Wrote:
(07-02-2017, 10:40 AM)felfail Wrote: I recently received the pinebook.
One of the first things I did was to flash an android image to a sd card (8 GB) using the PINE64 Installer.
Did not boot from the sd card. With any other os I flashed - pinebook did not boot from sd card.
Tried to turn into FEL mode (long press and then at least 3 short taps), did not work.
All in all, pinebook booted the eMMC image unless I did.
The sd card slot is working: If booted with the eMMC image OS I can read any sd card I plug into.
So I removed the eMMC and tried to boot from sd card, failed also. But switched into FEL mode.
I currently haven't build a serial console (via audio) connector cable (missing parts) to see what's happening while trying to boot from sd card.
My questions:
- Does anybody struggled into the same behaviour? Or what's wrong with sd cards the pine installer flashes?
- What are the FEL key's? Or how do I force the pinebook without removing the eMMC into FEL mode?
I have the same problem.
My problem has solved. My 128gb Samsung sdxc replaced to an Sandisc 16gb sdhc and it works well.
RE: New Pinebook 14'' does not boot from sd card - by tozsoferguson - 07-04-2017, 02:59 PM
  pinebook 1080p power/barrel connector/cable cel 0 553 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,387 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,238 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,654 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,365 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,632 09-25-2021, 12:03 AM
  SD card read/write troubles jezek 1 3,008 03-26-2021, 09:27 AM
Last Post: jezek
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,641 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,906 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,688 08-20-2020, 08:18 AM
Last Post: Reinoud
