Booting from eMMC with SD inserted?
(07-11-2017, 05:31 AM)falcon15500 Wrote:
(07-11-2017, 05:24 AM)MarkHaysHarris777 Wrote:
(07-11-2017, 05:22 AM)falcon15500 Wrote: Okay, so I am an idiot...
For anyone else who is having the same issues, the script:
/usr/local/sbin/pine64_remove_boot0.sh <device>
where <device> is your SDcard (eg: /dev/mmcblk1)
will stop the PB from trying to boot into the SDCard.
So now I can leave the SD inserted and it boots right into the eMMC.
M.
You should remove the SD card from the Rock64 if you're going to boot from the eMMC;  the bootup will get confused between the two; true.  But the worst of it from a maker standpoint is that the lower PI-2 bus gpio pins (blue bank, gpio1) are not available if you have the SD card plugged in.
Well I am on a Pinebook, so that's not really my biggest concern.  After I run the above script, it all works well.
M.
doh;  my bad
RE: Booting from eMMC with SD inserted? - by MarkHaysHarris777 - 07-11-2017, 05:51 AM
Rainbow Customised (encrypted) eMMC installation using Anarsoul's ArchLinux Blutkoete 24 50,152 05-02-2022, 12:59 PM
Last Post: thunderweasel
  Write image to eMMC - Pinebook 11.6" irongarment 4 9,014 01-04-2022, 09:22 PM
Last Post: irongarment
  Kali on SD does not Detect EMMC marianobilli 1 6,513 01-07-2021, 06:56 PM
Last Post: evilbunny
  pinebook black screen when booting with "different power mode than last used" penzoiders 12 27,997 04-27-2020, 06:27 AM
  Sd to eMMC badgeranduni 0 3,191 07-11-2019, 07:23 AM
Last Post: badgeranduni
  Problem booting from sd-card giel 14 23,628 06-27-2019, 10:28 PM
Last Post: pfeerick
  Problems putting Ubuntu (Xenial Mate) on my replacement eMMC. frank-zappa 11 21,654 05-01-2019, 12:09 PM
Last Post: frank-zappa
  DietPi not booting WZ9V 5 10,028 02-01-2019, 09:06 AM
Last Post: smallfish
  Problems to install qemu on Xenial Mate (for EMMC) demian 1 4,904 03-14-2018, 08:43 AM
Last Post: xalius
  How to test the emmc(usdhc2) diver and pwm backlight driver? vinothkumar 0 3,006 12-29-2017, 11:40 PM
Last Post: vinothkumar
