How to write image to emmc module on the pinebook
(06-26-2017, 12:08 PM)Luke Wrote:
(06-26-2017, 11:53 AM)eclay Wrote:
(06-26-2017, 11:42 AM)Luke Wrote:
(06-26-2017, 11:27 AM)eclay Wrote: Hello,
I've just received my pinebook today and am curious as to how one would write the OS image directly to the emmc module?  I've seen where the pine64-installer has an option to write to an emmc but it seems like this tool is for a x86/x86_64 system which the pine isn't.  Is there some emmc to usb adapter one would need to do this or is there some magic I'm missing?
You could in theory write an image directly to eMMC by putting the unit in FEL mode and using ayufan's boot tools. But the easy way is to use the pine installer to flash the desired image to an SD, insert the SD into the pinebook, and follow the instructions to flash the image to eMMC.
Thanks.  Once my pine charges I will give it a try.  It arrived completely dead and evidently it won't boot without some charge on the batteries.
Re. flat battery - I posted this earlier
Yep, I caught that post.  Didn't know if it was an older post or more recent.
I was able to use pine64-installer and choose ubuntu mate write to emmc and it worked as you described.
RE: How to write image to emmc module on the pinebook - by eclay - 06-26-2017, 01:15 PM
  pinebook 1080p power/barrel connector/cable cel 0 545 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,378 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,231 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,639 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,341 01-03-2022, 03:28 AM
Last Post: kqlnut
  Manjaro/Cinnamon customised on sdcard: how to transfer to emmc? quixote 0 1,518 10-16-2021, 02:03 PM
Last Post: quixote
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,615 09-25-2021, 12:03 AM
  SD card read/write troubles jezek 1 3,001 03-26-2021, 09:27 AM
Last Post: jezek
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,623 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,816 12-19-2020, 06:55 PM
Last Post: ron_burgundy
