Can not get board to boot up reliably
(06-12-2017, 10:56 AM)dkryder Wrote: so i was wondering while looking at your work if someone wanted to implement your work if it is a direct replacement of stock directories with your directories and during the unpacking some files were flagged as being the same with one set of those files iwith lower case filenames and the other with upper case filenames. i chose to not replace the uppercase with the lowercase. was that the correct choice? also the screen resolution listed in your Uenv.txt, is that the only resolution available or can i provide another like 1080p60? thanks
Sorry i just found out, that some files (in the netfilter kernel modules directory) are duplicated in the tar.gz You should be safe if you
select the latest version. I will make a new .tar.gz tomorrow. I did not disable any device driver option, so you should be able to select other resolutions. Although i only tested with the one in the config (i think 720p50).
Hopefully other people who are also having bootup problems can test with this kernel (settings) and let us know if it fixed the bootup problem.
This is still a workaround, but once confirmed working helps in finding a real solution.
If i have some time left i will also do some power measurements with a scope to see how the 5Volt line is behavng at startup. Just to rule out power issues that people are reporting. I don't know if anybody has done this already?
Can not get board to boot up reliably - by Leo - 04-24-2017, 01:41 AM
RE: Can not get board to boot up reliably - by pkfpeters - 06-12-2017, 03:01 PM
  Debian Base (3.10.102 BSP 2) won't boot without monitor Scion 7 18,524 09-16-2016, 03:58 PM
Last Post: Scion
  Possible to add a boot logo for boot? Darkshadow2913 4 13,328 09-09-2016, 06:02 AM
Last Post: Darkshadow2913
  Very long boot time with Debian image Xabaras76 5 11,895 07-14-2016, 03:49 PM
Last Post: Xabaras76
  Debian base(102) n xfce(101) does not boot HenryD 2 5,222 07-09-2016, 04:50 PM
Last Post: HenryD
