USB TTL cable no longer working
(03-09-2016, 02:45 PM)peterz Wrote:
(03-09-2016, 01:36 PM)tllim Wrote:
(03-09-2016, 12:09 PM)janjwerner Wrote: Have you tried the UART pins on the EXP port? I guess everything is wired to same place, but maybe there is some issue with a a connector.
Better use EXP port for UART console cable. The Euler port UART pin has voltage shifter and Euler port do not.
According pinout there is possible to have 6 UARTS (I plan to test this once I have my PINE64 in hands together with modules based on MAX3232 chip from ebay).
https://drive.google.com/a/pine64.com/fi...sp=sharing
1 of UARTs is on PI bus. I'd try this.
pin6   - GND
pin8   - UART_TXD
pin10 - UART_RXD
But don't know what device file each UART will have.
Try check what device files are there containing "tty" under /dev .
Combine both Euler and Pi2 bus, the maximum available UART is 4.
USB TTL cable no longer working - by taros - 03-09-2016, 11:53 AM
RE: USB TTL cable no longer working - by tllim - 03-09-2016, 01:36 PM
RE: USB TTL cable no longer working - by peterz - 03-09-2016, 02:45 PM
RE: USB TTL cable no longer working - by tllim - 03-09-2016, 03:04 PM
RE: USB TTL cable no longer working - by peterz - 03-09-2016, 03:09 PM
RE: USB TTL cable no longer working - by tllim - 03-09-2016, 04:02 PM
RE: USB TTL cable no longer working - by peterz - 03-09-2016, 04:59 PM
RE: USB TTL cable no longer working - by taros - 03-09-2016, 04:13 PM
RE: USB TTL cable no longer working - by tllim - 03-09-2016, 04:52 PM
RE: USB TTL cable no longer working - by taros - 03-09-2016, 04:57 PM
RE: USB TTL cable no longer working - by tllim - 04-06-2016, 03:53 PM
RE: USB TTL cable no longer working - by peterz - 04-07-2016, 01:44 AM
  Found this fully working RASPBIAN Image that boots to desktop speedro86 21 28,915 10-07-2017, 10:06 PM
Last Post: speedro86
  How to make multicast working on ubuntu and debian brengthdom 3 7,034 09-18-2016, 02:05 PM
Last Post: brengthdom
  Arch working! c0psrul3 1 2,868 05-01-2016, 08:55 PM
Last Post: Leoncito81
  Actual "working" 64 bit distro UnixOutlaw 2 5,268 03-16-2016, 02:25 PM
Last Post: umiddelb
