(ARCHIVED) Ubuntu Xenial Image (BSP Kernel)
#32
(03-21-2016, 09:27 AM)falk.ben@gmail.com Wrote: Getting an error when booting this.
[VFE_ERR Error] registering v412 subdevice No such device!
[VFE_ERR Error] vfe sensor register check error at input_num = 0
It just hangs here and I cannot log in:
https://goo.gl/photos/bhHRoa1ppmLH13ef7
Looks like i screwed something up.
Nothing screwed up. I assume you have not plugged network. The Ubuntu image comes with eth0 DHCP preconfigured and waits 5 minutes until it gives up connecting.
root@localhost:~# systemd-analyze blame
      5min 858ms networking.service
          2.790s dev-mmcblk0p2.device
           634ms systemd-udev-trigger.service
           630ms resolvconf.service
           547ms sys-kernel-debug.mount
           478ms systemd-logind.service
           461ms kmod-static-nodes.service
           456ms systemd-remount-fs.service
           421ms ondemand.service
           387ms eth0-mackeeper.service
           374ms systemd-modules-load.service
           368ms systemd-user-sessions.service
           346ms dev-hugepages.mount
           309ms systemd-journald.service
           241ms systemd-journal-flush.service
           171ms systemd-sysctl.service
           165ms dev-mqueue.mount
           158ms systemd-random-seed.service
           155ms sys-kernel-config.mount
           133ms rsyslog.service
           126ms sys-fs-fuse-connections.mount
           121ms systemd-tmpfiles-setup.service
            99ms console-setup.service
            98ms systemd-tmpfiles-setup-dev.service
            91ms systemd-timesyncd.service
            80ms systemd-udevd.service
            80ms systemd-fsck@dev-mmcblk0p1.service
            67ms systemd-rfkill.service
            31ms systemd-update-utmp.service
            28ms boot.mount
            17ms systemd-update-utmp-runlevel.service
            10ms rc-local.service
So either plug Ethernet, or remove the configuration from /etc/network/interfaces.d/eth0
Also note that the UART tty will not wait on networking by default in this image.
RE: Ubuntu Xenial Image (BSP Kernel) - by peterz - 02-28-2016, 03:48 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by faddah - 04-04-2016, 10:09 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by shockr - 02-29-2016, 06:37 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by mane - 03-07-2016, 09:58 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by mane - 03-09-2016, 10:16 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by mane - 03-09-2016, 12:37 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 03-09-2016, 01:17 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by tllim - 03-09-2016, 01:40 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by peterz - 03-09-2016, 02:18 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by tllim - 03-09-2016, 02:23 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by tllim - 03-09-2016, 03:01 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by mane - 03-09-2016, 03:18 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by mane - 03-11-2016, 02:42 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 03-11-2016, 03:02 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by mane - 03-11-2016, 05:33 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by longsleep - 03-21-2016, 12:56 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by joey - 03-23-2016, 11:54 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by joey - 03-28-2016, 08:59 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Jagmn - 03-30-2016, 10:54 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 03-30-2016, 01:52 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 03-30-2016, 02:13 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 03-30-2016, 02:21 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Jagmn - 03-30-2016, 02:27 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 03-30-2016, 02:38 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 03-30-2016, 04:35 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by koopa2k - 03-30-2016, 05:47 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 03-31-2016, 04:40 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 03-31-2016, 10:30 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 03-31-2016, 12:30 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-01-2016, 04:23 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Jagmn - 04-01-2016, 04:49 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-01-2016, 04:57 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-01-2016, 06:32 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-01-2016, 11:03 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by ViperVi - 04-01-2016, 11:10 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Xyntec - 04-02-2016, 10:43 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Xyntec - 04-02-2016, 11:36 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-03-2016, 07:00 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-03-2016, 08:39 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-03-2016, 09:23 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pirin - 04-22-2016, 04:40 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pirin - 04-23-2016, 06:24 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-03-2016, 07:37 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-03-2016, 08:20 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-03-2016, 10:21 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by yusijs - 04-03-2016, 06:49 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by faddah - 04-03-2016, 09:19 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by faddah - 04-04-2016, 05:00 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by faddah - 04-07-2016, 01:16 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by faddah - 04-07-2016, 02:03 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by joey - 04-03-2016, 09:34 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-04-2016, 09:13 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-05-2016, 04:40 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by faddah - 04-05-2016, 11:29 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-06-2016, 05:44 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-07-2016, 07:28 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Hart - 04-08-2016, 10:35 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by eender - 04-04-2016, 05:29 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by luggi - 04-05-2016, 11:10 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by joey - 04-06-2016, 12:06 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Hart - 04-08-2016, 01:54 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pirin - 04-12-2016, 10:27 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Vidiot - 04-12-2016, 10:48 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pirin - 04-15-2016, 07:24 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pirin - 04-21-2016, 07:16 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-21-2016, 08:44 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by joe - 04-22-2016, 05:28 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by joe - 04-22-2016, 11:16 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by joe - 04-22-2016, 05:43 AM
Ubuntu Xenial Image (BSP Kernel) - by rolfl - 04-24-2016, 08:35 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-26-2016, 05:47 PM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 05-07-2016, 02:56 PM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 05-09-2016, 04:25 AM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 05-09-2016, 06:14 AM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 05-09-2016, 09:34 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by frewind - 05-09-2016, 01:42 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 05-09-2016, 12:58 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by jl_678 - 05-10-2016, 08:26 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jl_678 - 05-10-2016, 11:30 AM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 05-12-2016, 12:28 PM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 05-15-2016, 11:30 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Rumen - 05-31-2016, 12:00 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 05-31-2016, 10:47 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-01-2016, 12:28 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-01-2016, 10:09 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-01-2016, 11:16 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-01-2016, 11:34 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-01-2016, 12:18 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by 3lliot - 06-02-2016, 11:05 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by 3lliot - 06-05-2016, 04:37 PM
Ubuntu Xenial Image (BSP Kernel) - by rolfl - 06-08-2016, 11:08 PM
Ubuntu Xenial Image (BSP Kernel) - by rolfl - 06-09-2016, 05:27 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-16-2016, 06:45 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-17-2016, 04:44 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by xalius - 06-17-2016, 12:14 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by jl_678 - 06-22-2016, 05:51 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by yodermk - 07-09-2016, 02:39 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by beh0211 - 07-17-2016, 08:20 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by ricblue - 07-17-2016, 01:44 PM
Ubuntu Xenial Image (BSP Kernel) - by hhbarnes - 07-22-2016, 06:23 AM
Ubuntu Xenial Image (BSP Kernel) - by hhbarnes - 07-25-2016, 04:26 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by xalius - 07-25-2016, 05:28 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by MrKings - 01-02-2017, 09:38 PM
Ubuntu Xenial Image (BSP Kernel) - by hhbarnes - 07-25-2016, 12:25 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Artyom - 07-28-2016, 05:41 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by xalius - 07-28-2016, 08:31 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by pekapa - 07-29-2016, 08:30 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Artyom - 07-29-2016, 10:39 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by pekapa - 07-29-2016, 04:19 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by wahlmat - 07-29-2016, 05:34 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by wahlmat - 08-01-2016, 03:28 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by xalius - 08-01-2016, 03:31 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by wahlmat - 08-02-2016, 10:11 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Artyom - 08-11-2016, 10:22 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by rallar8 - 08-11-2016, 01:34 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Artyom - 08-11-2016, 09:52 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Artyom - 08-13-2016, 09:17 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by sgjava - 08-12-2016, 11:36 AM
USB wifi with RTL8188CUS - by sgjava - 08-12-2016, 07:36 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by polv89 - 10-10-2016, 02:32 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pander - 10-16-2016, 08:24 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pander - 10-17-2016, 12:46 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pander - 10-18-2016, 03:36 AM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 11-02-2016, 01:14 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pander - 11-03-2016, 07:09 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by tllim - 12-18-2016, 03:24 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by sup - 01-01-2017, 11:55 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by utdrmac - 02-01-2017, 10:51 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by utdrmac - 02-01-2017, 11:52 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by sihil - 03-13-2017, 06:22 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by dkryder - 03-14-2017, 06:15 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by sihil - 03-15-2017, 03:31 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pander - 05-17-2017, 05:20 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by AA666 - 07-15-2017, 12:13 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by dkryder - 07-16-2017, 02:05 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by AA666 - 07-16-2017, 01:08 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 01-02-2018, 03:55 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by dkryder - 01-03-2018, 06:30 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 01-31-2018, 11:58 AM
  Ubuntu server 20.04 request phi0x 2 5,399 12-30-2020, 08:02 PM
Last Post: phi0x
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 21,658 08-30-2020, 10:35 AM
Last Post: jrronimo
  Kickstarter P64 with LCD, working image? MostHated 1 4,513 01-04-2020, 10:32 AM
Last Post: igorp
  USB Wireless Drivers with Longsleep Linux Kernel jacobscarter 15 25,035 03-06-2019, 02:26 PM
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 4,852 02-01-2019, 05:09 AM
  SPI on ubuntu IlyaM 4 9,267 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 8,702 05-18-2018, 03:33 PM
Last Post: Luke
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 4,032 04-16-2018, 03:09 PM
Last Post: Rocklobster
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 11,012 02-01-2018, 09:45 AM
Last Post: Partymack711
  PPTP doesnt work with ubuntu escovedo 2 8,806 08-23-2017, 09:28 AM
Last Post: gilbertotcc
