Read GPIO problem
(08-08-2017, 06:20 PM)pfeerick Wrote: My point the whole time as been simply that... if you export the pin, and it says that it's state is currently x, then it should damn well be x. not y, or z... x. The Raspberry Pi folks know that is what should be the case, so they made sure it was. Otherwise, the pin should have have a 'indeterminate' state, so that you know it hasn't been set yet. Wink
My 4K R64 board came in yesterday ; so I played with it most of the night,  found that it does NOT have this issue.   If the pin is exported its direction is set IN, the active_low is set 0 and its value is set "1".  If the pin is grounded than the value changes to "0".
So we need to get to the bottom of it;  is it a dts|dtb issue, a hardware issue with the PineA64+,  or a build issue ( something inconsistent with export somehow ).
Read GPIO problem - by shworker - 02-21-2017, 04:00 AM
RE: Read GPIO problem - by Techsensei - 02-21-2017, 06:41 AM
RE: Read GPIO problem - by shworker - 02-21-2017, 08:58 AM
RE: Read GPIO problem - by MarkHaysHarris777 - 02-22-2017, 04:23 AM
RE: Read GPIO problem - by aromring - 08-05-2017, 09:59 PM
RE: Read GPIO problem - by MarkHaysHarris777 - 08-05-2017, 10:24 PM
RE: Read GPIO problem - by pfeerick - 08-06-2017, 01:33 AM
RE: Read GPIO problem - by MarkHaysHarris777 - 08-06-2017, 10:38 AM
RE: Read GPIO problem - by pfeerick - 08-07-2017, 12:11 AM
RE: Read GPIO problem - by MarkHaysHarris777 - 08-07-2017, 07:21 AM
RE: Read GPIO problem - by pfeerick - 08-07-2017, 07:21 PM
RE: Read GPIO problem - by MarkHaysHarris777 - 08-07-2017, 11:10 PM
RE: Read GPIO problem - by pfeerick - 08-08-2017, 06:20 PM
RE: Read GPIO problem - by MarkHaysHarris777 - 08-15-2017, 02:24 AM
RE: Read GPIO problem - by martinayotte - 08-17-2017, 01:21 PM
  RPi.GPIO python module for Pine A64/A64+ aquilegia 97 133,398 02-23-2022, 02:56 PM
Last Post: ncs
  fm transmitter with gpio weasel18 2 4,884 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 3,634 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 11,248 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 11,332 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 11,953 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 31,972 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 14,915 03-11-2018, 01:52 AM
  GPIO fiq capability joseph 3 6,163 11-10-2016, 06:07 PM
Last Post: joseph
  RPI2-GPIO mus1c 6 9,193 09-22-2016, 05:28 AM
Last Post: mus1c
