Plex server
(05-03-2016, 09:36 AM)jpecora93 Wrote: Are you running headless?  I have the ubuntu image you recommended but it loads a desktop. I would prefer to run headless.
Of course I'm running headless and the image I recommended is of course also headless. It's this here: http://forum.pine64.org/showthread.php?tid=376
Don't use the crappy OS images from Pine64 wiki! This is what happens after an hour or so. A screensaver starts to eat up all your CPU, increases consumption and also temperatures that much that even throttling has to jump in and cooler state reaches/exceeds 4!! This is RPi-Monitor output made with the crappy Xubuntu OS image from Pine64 wiki. Starting at 13:40 the screensaver is taking over!
[Image: Bildschirmfoto%202016-05-03%20um%2017.44.12.png]
Also keep in mind that the screensaver heating up the SoC and utilising the CPU cores prevents Plex from being able to fully utilize the CPU. You should disable the lightdm service or better throw this crap in the bin and use the original OS image from longsleep!
Regarding 64 bit: I doubt this would help that much without special optimizations (NEON for example or maybe also being able to use HW accelerated video encoding). But I would suspect this will be available for RPi's VideoCore VPU earlier than for A64. We'll see and still the 'one USB 2.0 connection to the outside' limits every RPi to be used as media center.
Plex server - by arghne - 12-12-2015, 01:44 AM
RE: Plex server - by tllim - 12-12-2015, 06:06 AM
RE: Plex server - by tkaiser - 12-12-2015, 06:16 AM
RE: Plex server - by PineTree - 12-15-2015, 12:00 PM
RE: Plex server - by f3bruary - 12-13-2015, 08:11 AM
RE: Plex server - by mattjdalby - 05-01-2016, 05:20 PM
RE: Plex server - by Miedon - 05-02-2016, 05:48 AM
RE: Plex server - by tkaiser - 05-02-2016, 11:28 AM
RE: Plex server - by jpecora93 - 05-03-2016, 07:55 AM
RE: Plex server - by tkaiser - 05-03-2016, 08:06 AM
RE: Plex server - by jpecora93 - 05-03-2016, 09:36 AM
RE: Plex server - by tkaiser - 05-03-2016, 09:52 AM
RE: Plex server - by By-Jokese - 05-03-2016, 12:31 PM
RE: Plex server - by tkaiser - 05-03-2016, 12:40 PM
RE: Plex server - by By-Jokese - 05-03-2016, 02:10 PM
RE: Plex server - by curiousgally - 05-05-2016, 10:29 AM
RE: Plex server - by tkaiser - 05-05-2016, 10:48 AM
RE: Plex server - by melao - 06-07-2016, 09:16 PM
RE: Plex server - by swrtvrk - 05-07-2016, 01:34 AM
RE: Plex server - by tkaiser - 05-07-2016, 01:48 AM
RE: Plex server - by paulh77 - 05-07-2016, 02:00 AM
RE: Plex server - by tkaiser - 05-07-2016, 02:06 AM
RE: Plex server - by paulh77 - 05-07-2016, 02:17 AM
RE: Plex server - by tkaiser - 05-07-2016, 02:54 AM
RE: Plex server - by greig - 05-07-2016, 07:27 AM
RE: Plex server - by tkaiser - 05-07-2016, 07:33 AM
RE: Plex server - by greig - 05-07-2016, 04:34 PM
RE: Plex server - by tkaiser - 05-08-2016, 01:44 AM
RE: Plex server - by malevolent - 05-09-2016, 01:50 PM
RE: Plex server - by By-Jokese - 05-09-2016, 02:17 PM
RE: Plex server - by jpecora93 - 05-09-2016, 02:19 PM
RE: Plex server - by clarkss12 - 07-04-2016, 05:35 PM
RE: Plex server - by malevolent - 05-09-2016, 05:24 PM
RE: Plex server - by jpecora93 - 05-10-2016, 10:59 AM
RE: Plex server - by malevolent - 05-10-2016, 12:09 PM
RE: Plex server - by rahlquist - 05-10-2016, 12:23 PM
RE: Plex server - by longsleep - 05-10-2016, 12:23 PM
RE: Plex server - by malevolent - 05-10-2016, 01:16 PM
RE: Plex server - by longsleep - 05-10-2016, 01:24 PM
RE: Plex server - by malevolent - 05-10-2016, 01:35 PM
RE: Plex server - by longsleep - 05-10-2016, 01:47 PM
RE: Plex server - by malevolent - 05-10-2016, 02:33 PM
RE: Plex server - by tkaiser - 05-10-2016, 11:46 PM
RE: Plex server - by FreakingNoobs - 05-16-2016, 07:11 PM
RE: Plex server - by rahlquist - 05-16-2016, 10:47 PM
RE: Plex server - by By-Jokese - 05-17-2016, 04:48 AM
RE: Plex server - by MrWizerd - 05-26-2016, 06:10 AM
RE: Plex server - by By-Jokese - 06-26-2016, 10:35 AM
RE: Plex server - by melao - 06-26-2016, 01:52 PM
RE: Plex server - by By-Jokese - 06-26-2016, 04:16 PM
RE: Plex server - by clarkss12 - 06-30-2016, 08:22 PM
RE: Plex server - by robb01 - 07-09-2016, 08:26 PM
RE: Plex server - by robb01 - 07-09-2016, 10:42 PM
RE: Plex server - by clarkss12 - 08-06-2016, 06:54 PM
RE: Plex server - by bigatl22 - 09-01-2016, 08:38 AM
RE: Plex server - by PapaGrimm - 10-11-2016, 12:51 AM
RE: Plex server - by jpecora93 - 11-13-2016, 11:12 AM
Plex server - by Moshe.Vazan - 07-06-2018, 10:36 AM
Plex Server on Pine64 - by jpecora93 - 05-02-2016, 10:56 AM
RE: Plex Server on Pine64 - by tkaiser - 05-02-2016, 11:34 AM
  Mastodon instance \ Nextcloud Server fearg 1 4,628 03-31-2020, 08:18 PM
  Turn your Pine64 into a music server with mpd JulianM 2 11,142 03-23-2017, 10:50 PM
  Plex server arghne 48 54,264 03-22-2017, 04:15 AM
Last Post: pineadmin
  Pine64 as NAS/Media Server VandaL.pr! 1 6,258 12-27-2016, 10:48 AM
Last Post: Luke
  3d printer server oldsmarracin 3 5,650 09-13-2016, 02:43 AM
Last Post: JAYJAYN
  Cannot install Plex Media Server under Arch Linux malevolent 2 5,654 09-11-2016, 12:20 PM
Last Post: ChrisLane
  Building Stratum One NTP Server lospinos 5 8,968 08-23-2016, 09:23 AM
Last Post: MarkHaysHarris777
  Starbound Server. Is the Pine64 capable? iamfallen 1 4,008 08-03-2016, 10:36 AM
Brick Minecraft Server chrislink14 16 29,581 05-06-2016, 08:03 AM
Last Post: jeremycobert
  Media server montero65 3 6,173 04-28-2016, 06:02 PM
Last Post: queonda
