Windows 10 IoT finally released on Pine A64 platform
#22
Hi all,
Using windows10IoT_pine64_RS1_20161121.ffu (OS Version: 10.0.14393.0), cant seem to get it to boot with WiFi/Bt module, BSOD every time.
Remove the module and it starts up fine.
Windows Update installs: 10.0.10595
and then when rebooting, it just hangs.
This is what I get on the console.
��%���5jR�AXP NumberOfHandles = 1                 �U͉ɂJ�с�QIQ�"""jԤ�5�!�����
open hci clock usbc_no:1, is_ohci:1
parser fetch usbc1 usb_drv_vbus_gpio failed
Loading driver�SunxiEthDxeEntryPoint: phy mode = rgmii
gmac_rgmii_select
Loading drive�no key pressed
Sunxi BootCmd = boot-normal
Loading drive�Loading�Loading dr�Loading d�Loading driver at �Loading driv�Loading drive�[PWM Msg]:request pwm success,pwm-base=0x0, pwm_number=1,pwm = 16.
enable power vcc-hdmi-33, ret=0
drv_disp_init finish
[Disp Msg]:board_display_device_open_lcd
[Disp Msg]:boot_disp.output_mode=4
[Disp Msg]:disp0 device type(0) enable
lcd_panel_fun[0].cfg_open_flow is NULL
enable power vcc-dsi-33, ret=0
disp_sys_register_irq, irqNo=121, Handler=0xBE592F09, pArg=0xBE316810
lcd_panel_fun[0].cfg_panel_info is NULL
disp 0, clk: pll(330000000),clk(330000000),dclk(55000000) dsi_rate(55000000)
    clk real:pll(330000000),clk(330000000),dclk(82500000) dsi_rate(148500000)
[Disp Msg]:board_display_device_open_hdmi
[Disp Msg]:disp1 device type(0) enable
attched ok, mgr1<-->device0, type=4, mode=4
disp_sys_register_irq, irqNo=119, Handler=0xBE5989E5, pArg=0xBE316610
plugin
[Disp Error]:fetch script data boot_disp.output_full fail
[Disp Msg]:screen_id =1, screen_width =1280, screen_height =720
[Disp Msg]:frame buffer address BF000000
[Disp Msg]:bitcount = 32
[Disp Msg]:screen_id =0, screen_width =1024, screen_height =600
Loading driver a�Loading driver �Loading driver at 0x�Loading drive�Loading dri�Loading driver�Loading driver at 0x000BE1AF000 EntryPoint=0x000BE1B26A1 Fat.efi
Loading driv�Driver CB933912-DF8F-4305-B1F9-7B44FA11395C was discovered but not load�+&��+LL'LL���O&Z�+&��+LL'LL��+&��+LL'LL���O&Z�+&��+LL'LL��+&��+LL'LL���O&Z�+&��+LL'LL��+&��+LL'LL���O&Z�+&��+LL'LL��+L[���M[�+ML[�+L[���Sk�E�jمɥ
������꽽ѵr�ɵ��5jRT����݁��с������5jR�Loading driver�ACPI: LoadAcpiFromVolume() failed to open directory
ACPI: Loading ArmBgrt.acpi
read file is NULL
read file is NULL
ACPI: Loading ArmCsrt.acpi
ACPI: Loading ArmDbg2.acpi
ACPI: Loading ArmDsdt.aml
ACPI: Loading ArmFacp.acpi
ACPI: Loading ArmGtdt.acpi
ACPI: Loading ArmMadt.acpi
ACPI: Loaded 7 tables
Install ACPI table by partition file success
no battery exist
read file is NULL
read file is NULL
read file is NULL
Read Logo file Fail, Please Check file exist
show Bootlogo error: Unsupported
  PEI    644 ms
  DXE   1577 ms
  BDS    333 ms
Total Time = 2554 ms
try removeable media boot
Any ideas what is wrong?
Cheers
-Anders
RE: Windows 10 IoT finally released on Pine A64 platform - by carlberg - 02-06-2017, 08:35 AM
  Windows 10 IoT Enterprise? roybridge 1 7,345 03-06-2019, 02:42 PM
  Windows IoT BSP dvescovi 16 28,869 09-02-2018, 06:35 PM
Sad Windows 10 iot ffu lawrencejd 1 5,175 07-19-2018, 10:40 PM
Last Post: KNERD
  Win10 IoT (PINE A64(+)) 10.0.15063.0_20170602 pineadmin 30 53,197 05-18-2018, 07:05 AM
Last Post: dkryder
  +LTS/SOPINE Can Win10 IOT be used on PINE A64-LTS? uart 1 4,682 03-09-2018, 11:25 PM
  unable to deploy my application to the Pine using Visual Studio 2017 Matthew 9 13,857 03-08-2018, 04:20 AM
Last Post: zio69
  Will Windows 10 work with the new Rock board? WhiskerBiscuit 2 6,865 09-03-2017, 07:22 PM
  Windows 10 and .Net Core running for a day hugob 2 7,034 08-23-2017, 11:17 AM
Last Post: hugob
Star Windows IoT BSP on Github!!!! Add UEFI src code! Leeway213 5 11,972 06-25-2017, 07:42 PM
Last Post: Leeway213
  Pine 64 on 512MB embedder 3 7,899 12-19-2016, 07:56 PM
Last Post: Toriless
