PinePhone Dock with laptop?
(12-03-2023, 10:15 PM)Kevin Kofler Wrote: Can you try booting a GNU/Linux live image on your laptop? Any distro will do, really. Just put the live image onto an empty (or emptiable, i.e., with no important data on it) USB stick and boot it. If the distro recognizes the Ethernet port, you will know that it is a driver issue and that you need to find a Windows driver for the device if you want it to work under Windows. If it also does not work in GNU/Linux, then it is likely a hardware incompatibility.
Good idea... I have a Linux distro here somewhere on a separate SSD... Thanks for the suggestion. No luck on a Windows driver... but that would be awesome if I could find one.
PinePhone Dock with laptop? - by Mikey1977Y2J - 12-02-2023, 11:51 AM
RE: PinePhone Dock with laptop? - by Kevin Kofler - 12-03-2023, 10:15 PM
RE: PinePhone Dock with laptop? - by Mikey1977Y2J - 12-12-2023, 05:43 PM
  Case for Pinephone totilele 13 7,564 04-11-2024, 11:48 AM
Last Post: gramonyl
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,276 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 472 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 542 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,055 10-20-2023, 04:11 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,605 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,098 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 37,929 08-07-2023, 06:12 AM
Last Post: mikeb
  PinePhone flex breakout board with Grove female header jnpine 0 653 08-04-2023, 10:47 PM
Last Post: jnpine
  Pinephone Keyboard Connector dorkydev 0 660 07-19-2023, 04:40 AM
Last Post: dorkydev
