2nd NetBSD boot goes dark
As it happens, I did try out the NetBSD u-boot. I then removed the back of the case, to find that shorting SPI pin 6 to ground isn't so easy as presented in the pine64 wiki, now that there's a cover plate that would have to be pried off. Luckily, I found that Manjaro would sometimes boot from the eMMC if I held the power button down long enough, and from there I could zero the SPI device up to a point. So luckily I'm back where I started.
I don't know why the NetBSD rockpro64 u-boot didn't work, but it sure didn't. Possibly the device isn't adequately supported right now as something that can be dd'd to, and if I carted it over to Linux and flashcp'd it it would be fine. Or I could get myself into a situation where I have to take a chisel to the board, so ... I don't know, maybe not.
tow-boot was mainly just erratic - sometimes it couldn't boot the SD, but if you keep trying, it would get it eventually. Or it would freeze up. I'd be using it, if it didn't knock out the USB wifi device. It's ragged, but it can choose a boot device.
Anyway ... the black screen problem returned right away after I zeroed the SPI, which didn't fit the normal pattern since it was after a Manjaro session.
2nd NetBSD boot goes dark - by donn - 11-15-2023, 11:25 AM
RE: 2nd NetBSD boot goes dark - by donn - 11-16-2023, 11:31 AM
RE: 2nd NetBSD boot goes dark - by KC9UDX - 11-16-2023, 02:02 PM
RE: 2nd NetBSD boot goes dark - by donn - 11-16-2023, 04:49 PM
RE: 2nd NetBSD boot goes dark - by KC9UDX - 11-16-2023, 04:59 PM
RE: 2nd NetBSD boot goes dark - by additionlung - 02-21-2024, 10:44 PM
RE: 2nd NetBSD boot goes dark - by KC9UDX - 02-22-2024, 03:59 AM
  NetBSD 1.0 runs down battery donn 13 1,667 11-15-2023, 04:05 PM
  Booting NetBSD untitled 12 6,240 08-30-2022, 01:23 AM
Last Post: untitled
  NetBSD on the Pinebook Pro in August 2022 - or not? KC9UDX 6 3,846 08-24-2022, 01:49 AM
  NetBSD and pinebook keyboard/trackpad firmware updater mrgtwentythree 5 10,016 05-16-2021, 07:37 PM
Last Post: mrgtwentythree
  NetBSD Der Geist der Maschine 76 111,590 05-16-2021, 02:43 PM
Music NetBSD and USB "sound cards" KC9UDX 2 5,412 05-07-2021, 12:11 PM
Last Post: elimark1
Question Issues Installing NetBSD on a PineBook Pro ReleaseTheGeese 14 15,247 01-31-2021, 11:20 AM
  NetBSD -Current binaries BronzeBeard 8 11,751 12-31-2020, 08:38 PM
Last Post: BronzeBeard
Thumbs Up My NetBSD on Pinebook Pro journey KC9UDX 11 18,899 12-06-2020, 08:26 PM
