Replacement main board for Developers
Interesting. It sounds like classic bad RAM or overheat. Have you tried throttling the CPUs?
The high pitch whine may or may not be normal with the battery disconnected. I wonder if you had a shorted battery which damaged the power circuit. You may need to get both a main board and a battery. (There was a thread here recently about buying batteries).
I wonder if @tllim has a word on a replacement main board.
:wq
[ SRA accepts you ]
Replacement main board for Developers - by mozes - 11-10-2023, 04:25 AM
RE: Replacement main board for Developers - by KC9UDX - 11-13-2023, 04:46 AM
  Bad replacement battery? chris88233 3 484 02-19-2024, 04:59 PM
  Replacement battery for PineBook Pro DrYak 3 1,191 11-07-2023, 10:09 AM
Last Post: DrYak
  Battery replacement mjc 2 2,960 09-26-2023, 01:08 AM
Last Post: david-lechner
  Replacement scissor switches (ANSI keyboard)? zackw 3 3,916 08-09-2021, 09:20 PM
  Pinebook Pro/Pinetab replacement as400 11 11,426 07-30-2021, 04:40 AM
Last Post: as400
  Replacement board avaliability mrjay 1 2,494 07-06-2021, 04:08 PM
  Minimum daughter boards/peripherals required for main board to boot cmicallef 5 4,726 03-12-2021, 10:10 PM
Last Post: cmicallef
  Replacement for video cable (EDP to LCD/camera)? pnwkayaker 2 4,097 10-13-2020, 08:42 PM
Last Post: pnwkayaker
  Replacement internal antenna? azuntik 6 8,133 09-09-2020, 10:07 PM
  PBP Speaker Replacement 8jef 25 34,460 09-09-2020, 05:09 AM
Last Post: speculatrix
