How can I open an Abiword file from an external SD card with Abiword?
(08-24-2023, 08:31 AM)Peter Gamma Wrote: I really suffer from not being able to edit Abiword files on my external Pinephone SD card. A  feature if it worked which would make out of the Pinephone an outstanding device which can do something which Android phones cannot do. Being able to edit office files on the external SD card, is this not a reason to buy and recommend a Pinephone for this? The solution of Alaraajavamma with the Nautilus file manager seems to be the most promising solution to solve this problem. On which distro do you install Nautilus on your  Pinephone, Alaraajavamma?
I just installed Nautilus on Postmarket OS Phosh Edge and it works perfectly.
I can also see my sd card and I can also use "Open with" gui and choose abiword Smile.
Maybe you are in stable and there are some issues there?
RE: How can I open an Abiword file from an external SD card with Abiword? - by alaraajavamma - 08-24-2023, 10:28 AM
  How can I get the permissions to write to the external SD card ...? Peter Gamma 9 1,919 10-20-2023, 12:32 PM
Last Post: Peter Gamma
  How to write the the external SD card with Abword? Peter Gamma 0 513 08-27-2023, 01:10 AM
  How to start Abiword if I hit enter if an Abiword document is market with PCManFM? Peter Gamma 0 514 08-22-2023, 12:41 PM
  How to include desktop file and icon in a postmarketos package patrickMcDonald 0 599 07-27-2023, 12:34 PM
Last Post: patrickMcDonald
  File Manager that Can Access FTP Local Network? jakfish 1 1,090 02-19-2023, 02:31 PM
Last Post: jakfish
  Help how to mount SD-Card chadwick 8 7,838 11-30-2021, 11:12 PM
Last Post: chadwick
  How to import contacts with a .vcf file? LNXGUY 2 2,744 11-23-2021, 11:45 AM
Last Post: chadwick
  File selector dialogue crashes Firefox stozi 1 2,720 11-22-2020, 01:40 AM
Last Post: quantumphoton
  "save as" dialog file browser crashed and gone quantumphoton 0 1,646 10-25-2020, 06:50 PM
  PP boots into factory test even if flashed sd card is inserted hapster 5 6,579 04-13-2020, 02:34 PM
Last Post: MartijnBraam
