Mobian .desktop file creation
(07-23-2023, 11:55 AM)alaraajavamma Wrote:
(07-22-2023, 01:34 PM)MadameMalady Wrote: So, that does make the icon show up correctly, but it doesn't run any of the commands in the opened terminal bc it's read-only, is that related at all or a different issue?
I am not that familiar with Python but I think it might work if you put the exec line like this:
Exec=bash -c 'cd /home/mobian/MyWaydroidManager/ && python3 MyWaydroidManager.py'
or
Exec=python3 /home/mobian/MyWaydroidManager/MyWaydroidManager.py
or maybe Big Grin
Exec=/usr/bin/env python3 /home/mobian/MyWaydroidManager/MyWaydroidManager.py
Just throwing curve balls but either of those should not make any harm so feel free to try Smile
If your desktop file does not open terminal at all you might want to install gnome-terminal and try then again Smile (recent versions of console will support opening trough desktop files but that is not the case with all version)
Thanks for taking the time to help with this, I tried all three of those and I still get a terminal that opens to a Read-Only file system, and tells me it cant 'cd to scripts'
-_-.....
So close to figuring this out..
Mobian .desktop file creation - by MadameMalady - 07-20-2023, 01:08 PM
RE: Mobian .desktop file creation - by MadameMalady - 07-23-2023, 02:53 PM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 2,446 04-28-2024, 01:52 AM
Last Post: diederik
  Disable the GDM service in Mobian. mburns 0 498 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 965 11-18-2023, 08:21 AM
Last Post: crocspot
  "failed to start simple desktop display manager" PinePhonePro / Plasma Beta15 RC4 OhMeadhbh 1 716 11-09-2023, 07:39 AM
Last Post: mburns
  Fix the Mobian Weather App mburns 0 534 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 771 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 639 10-14-2023, 11:57 AM
Last Post: mburns
  Mobian libnotify custom notifications MadameMalady 5 1,510 08-01-2023, 08:51 AM
Last Post: MadameMalady
  XFCE mobian running nicely but some oddities grump_fiddle_reinstall 0 834 07-01-2023, 08:18 AM
  [Mobian] : Battery consumption and OS compatibility freelectro 2 1,149 06-02-2023, 06:55 AM
Last Post: Fred Zyphal
