PineTab 2 (arm64) thoughts and questions
(06-14-2023, 08:17 PM)acruhl Wrote:
(06-13-2023, 01:51 AM)Corconegre Wrote: 3- You should be able to install packages from somewhere else or compile them yourself and this should not break your system, unless you remove things or there's conflicts, just read about the package before doing it. (i installed Vivaldi snapshot from their site and it's not in the repos).
Why do you say qemu it's not available?
The software you mention is in the official Extra repository of arch: https://archlinuxarm.org/packages/aarch6...system-arm so you should be able to download and install it.
In the terminal type "sudo pacman -Ss qemu" this will list "qemu" packages on my device i get a bunch of them which means they exist and i can install them.
Just checking if you don't see them for any other reason.
If they don't show up in "discover" try the terminal, i don't like discover much (might be personal but it does not really work well for me)... pacman is the command to install packages in arch (https://wiki.archlinux.org/title/pacman)
About the plasma task bar, what issue you have when you pin programs?
Hope any of this helps out Smile
Yes, qemu does not show up in the Discover GUI but it does on the pacman command line. I didn't know there was a difference.
When I right click on the Firefox icon in the task bar and choose to pin it, the next time I log in or reboot I get a blank screen after entering my password to log in. It seems like Plasma struggles with some of it's own config a little bit, it gets very laggy when I make changes. Anyway, not sure if that's a PineTab problem, probably not.
It was my first time with discover also, but i run manjaro on my desktop so i had experience with pacman, i tried and... surprise!
Except for pamac any other gui i tried for this does not really work (my experience)
About the laggy issue the only thing i can say is i do not experience it, not sure how to help here...
Was tinking about the amount of ram (mine has 8) but not even sure it can be related.
I guess this happens with any program not just firefox.
Maybe someone else can help.
RE: PineTab 2 (arm64) thoughts and questions - by Corconegre - 06-15-2023, 01:31 PM
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 8,273 02-28-2024, 05:03 AM
Last Post: Surehand53
Wink Screen protector for PineTab 2 vatin 0 599 11-18-2023, 01:31 AM
Last Post: vatin
  PineTab 2 Dead Screen Kramey 16 5,098 08-12-2023, 05:44 PM
Last Post: Kramey
  pinetab 2 not booting ajhiii070 5 1,964 08-07-2023, 01:46 PM
Last Post: r.aliaskarov
  does the pinetab "just worK"? averageconsumer445 19 4,954 07-15-2023, 10:31 AM
Last Post: dachalife
  Pinetab-V shipping Status? jfstepha 6 2,560 07-12-2023, 03:23 PM
Last Post: ChromaticHamster
  No WiFi or Ethernet on vanilla PineTab 2 from the factory? SmittyWerbenyegermanjenson 6 2,443 06-06-2023, 05:26 PM
Last Post: fxc
Star Looking for a Pinetab [EU] Glenn 2 2,713 01-24-2023, 06:12 PM
Last Post: Louis
  Looking to buy a PineTab Yair22 2 2,573 01-24-2023, 06:10 PM
Last Post: Louis
  Pinetab for sale w/ keyboard (Denmark, EU) [sold] Louis 0 753 01-24-2023, 06:01 PM
Last Post: Louis
