Followed the blog post to install Fedora: PBP not booting anymore
(05-30-2023, 08:22 PM)wdt Wrote: where you may have gone wrong is using u-boot.itb on the spi
Just a guess
It  migth be simpler to compile rkdeveloptool  to blank the spi
You do have to find miniloader.bin suitable for the hardware
(this is what initializes mem and usb ports),,, ie
rkdeveloptool ld (it will say loader or maskrom, maskrom is what you want, remove ALL media)
rkdeveloptool rd 3 (only if needed, changes it to maskrom), check with ld
rkdeveloptool db miniloader.bin..... and now rkdeveloptool will do every command
mkimage comes with uboot (for boot.cmd/boot.scr),, the command is
mkimage -C none -A arm -T script -d boot.cmd boot.scr
or maybe simpler, short spi clock pin to ground the first 5 sec of boot, then it can't interfere
Assumes you have a bootable sd or emmc
Thanks for your answer but after searching on the internet about this "miniloader.bin" I could find literally nothing about it...
But anyway, I actually just found out WHAT I DID WRONG:
I didn't read correctly the blog post and I wrote the u-boot.itb at offset 6000 instead of 60000  Dodgy
The day after I screwed up my SPI, someone posted a new blog post on Reddit on how to install Fedora on the RockPro64 so I'm 99% sure it will work the same way on my Pinebook Pro if at least I can correctly write u-boot to the SPI without doing any mistake...
The way to enter in Maskrom with the recover and reset buttons doesn't work for me so I'm still waiting for the pry tools I ordered to arrive.
RE: Followed the blog post to install Fedora: PBP not booting anymore - by koenigs - 05-31-2023, 02:47 AM
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,971 08-03-2023, 03:30 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,543 04-23-2023, 06:58 AM
Last Post: acruhl
Exclamation PineBook Pro shuts down immediately after booting zogkarndon 5 2,055 01-10-2023, 10:16 AM
Last Post: Perl6_user
  Use SD to install new OS over pinebook debian Rudy558 9 10,908 09-25-2022, 01:19 AM
Last Post: jackwilson
  MiniConda Install Issues nixyhustle 0 814 09-16-2022, 10:06 PM
Last Post: nixyhustle
  Does anyone know how to install levinsboot on pbp? computerc 0 651 09-05-2022, 03:52 PM
Last Post: computerc
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,445 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Total Noob. Need help booting from SD Mattchublean 18 13,639 07-23-2022, 11:54 PM
Last Post: LivingLinux
Wink Booting Windows on bare-metal rk3399 SBC (no linux involved) strongtz 9 10,660 05-26-2022, 11:36 PM
Last Post: strongtz
  PInebook not booting with eMMC enabled aragaer 4 4,305 10-25-2021, 09:11 PM
