CR2032 Battery holder - sanity check
I assume its for the higher-than-typical RTC current draw spec of 1 mA, compared to typical.
There's no peak current draw issue, so would expect its a battery lifetime issue.
CR2032 Battery holder - sanity check - by xalius - 07-22-2016, 04:30 PM
RE: CR2032 Battery holder - sanity check - by DonFL - 07-25-2016, 07:23 AM
Rainbow Lithium battery temperature readout? GregH 0 1,890 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 67,101 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 4,239 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 4,604 02-17-2017, 08:18 PM
  Battery temp pin? SvdSinner 1 3,855 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 52,270 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 9,437 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 2,477 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 2,377 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 18,064 02-18-2016, 05:17 AM
Last Post: German
