CR2032 Battery holder - sanity check
Nope, no need for a capacitor. This is a simple battery holder, nothing more exotic.
Common lead is attached to one of the +/- junctions (if you follow the imprint on the case), positive lead , thru the switch, to the other +/- junction.
Going to pick up a couple batteries tomorrow, but just not seeing how you get 3V with them installed as per the case imprints. Install them the same way, and you have two 3V cells in parallel, as I would think was intended.
CR2032 Battery holder - sanity check - by xalius - 07-22-2016, 04:30 PM
RE: CR2032 Battery holder - sanity check - by DonFL - 07-23-2016, 07:23 PM
Rainbow Lithium battery temperature readout? GregH 0 1,897 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 67,425 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 4,256 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 4,624 02-17-2017, 08:18 PM
  Battery temp pin? SvdSinner 1 3,865 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 52,493 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 9,467 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 2,482 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 2,382 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 18,120 02-18-2016, 05:17 AM
Last Post: German
