CR2032 Battery holder - sanity check
(07-23-2016, 06:45 AM)@lex Wrote: You need both coin inserted. It seems it gets 6v dropped to 2.85v and this works.
---------|    + up  |  - up  |
So you're saying its not meant to be two 3V cells in parallel, its meant to be 6V, and then regulated on-board?
I'm very leery of that in that the AAA battery holder looks like its 2 AAA cells, so 2x1.5V, a 3V output...would expect the 2032 holder to be the same design since its intended for the the very same function. Schematic for the 1 GB board that's posted on the wiki also indicates, if I'm interpreting the schematic correctly, 3V for RTC, with a direct connection to the PMIC chip, which also shows a spec of 3V max for RTC input.
CR2032 Battery holder - sanity check - by xalius - 07-22-2016, 04:30 PM
RE: CR2032 Battery holder - sanity check - by DonFL - 07-23-2016, 01:50 PM
Rainbow Lithium battery temperature readout? GregH 0 1,896 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 67,330 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 4,254 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 4,620 02-17-2017, 08:18 PM
  Battery temp pin? SvdSinner 1 3,865 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 52,435 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 9,464 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 2,482 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 2,381 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 18,116 02-18-2016, 05:17 AM
Last Post: German
