Is it normal for the pinephone to "discharge" after fully charged on multiple OS?
Edit: Just an update, I don't know why but it seems to be charging at some point on it's own after a while now. When and why it does seems a bit unknown to me but just thought I'd say that it's working good enough for me now.
(05-10-2023, 09:24 PM)Kevin Kofler Wrote: It can slightly discharge after reaching 100% so that the battery is not stressed by constant charging, but it should not go as low as 70% while plugged in, mine does not do that. At something like 90-95%, it should start charging again.
Thanks. Is there possibly something I can do if it is going lower than it's supposed to then?
RE: Is it normal for the pinephone to "discharge" after fully charged on multiple OS? - by Shad190 - 05-10-2023, 10:37 PM
  Pinephone boot. Richy_T 2 58 9 hours ago
Last Post: zetabeta
  PinePhone - boot from microSD laserpyramid 9 838 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 418 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 283 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,694 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,919 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 660 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,495 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 536 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,779 12-22-2023, 03:44 PM
