Can't boot when SD card inserted
TL;DR I'm experiencing this issue but with the Pinebook Pro and the solution outlined there isn't helping me: https://forum.pine64.org/showthread.php?tid=6819
So I've recently upgraded the eMMC in my Pinebook Pro to 128 GB, and I wanted to use an SD card as the home partition. I've partitioned it as the following:
Lambda /etc # parted /dev/mmcblk1
GNU Parted 3.5
Using /dev/mmcblk1
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) p
Model: SD SD256 (sd/mmc)
Disk /dev/mmcblk1: 256GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start   End    Size   File system  Name     Flags
1      1049kB  256GB  256GB  f2fs         primary
(parted)
I've formatted /dev/mmcblk1p1 as f2fs, and added a line for it in /etc/fstab, but if I reboot the Pinebook with the SD inserted, I get a black screen, and the power LED stays red. If I boot with it removed, it boots from eMMC just fine, and if I re-insert it quickly enough it's mounted as desired.
This is a minor inconvenience, though, so I'd like to get to the bottom of why it's happening, or at least figure out how I might be able to fix it.
I'd previously flashed (using dd) the latest Armbian image to this particular SD card that I'm using, so prior to making the partition table, I zeroed out the first MiB to attempt to get rid of any sort of U-Boot data.
So, what do I need to do to have my Pinebook Pro boot to eMMC in the case that the inserted SD card isn't meant to be bootable? (I'd still like to be able to "rescue" my system by removing the one containing the home partition and inserting a bootable SD in its place.)
Can't boot when SD card inserted - by 0daysfordays - 09-04-2022, 03:40 PM
RE: Can't boot when SD card inserted - by wdt - 09-05-2022, 07:28 AM
RE: Can't boot when SD card inserted - by wdt - 09-17-2022, 06:59 PM
  uboot wont boot to SD card after upgrade jbradley419 7 830 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 290 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,224 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 694 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 586 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,179 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,875 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 802 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,945 06-14-2023, 07:20 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,437 05-20-2023, 01:02 AM
Last Post: jackwilson
