unable to boot after manjaro update
Try a Ctrl+Alt+F2 after that screen appears. Should drop you in command line mode and you could maybe login that way. Then run dmesg to see what it might say.
unable to boot after manjaro update - by gega - 08-29-2022, 01:59 PM
RE: unable to boot after manjaro update - by gega - 08-29-2022, 08:22 PM
RE: unable to boot after manjaro update - by gega - 09-12-2022, 09:40 PM
RE: unable to boot after manjaro update - by cypresstwist - 09-13-2022, 02:05 AM
RE: unable to boot after manjaro update - by gega - 10-28-2022, 01:39 AM
RE: unable to boot after manjaro update - by wdt - 10-28-2022, 01:18 PM
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,436 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  Minimum daughter boards/peripherals required for main board to boot cmicallef 5 4,706 03-12-2021, 10:10 PM
Last Post: cmicallef
  NVME SPI Update not booting SD Card WZ9V 5 6,514 10-18-2020, 08:36 PM
  How to boot from USB? kendew 7 12,556 10-08-2020, 07:06 AM
Last Post: Arwen
  Pinebook Pro Boot Issues - Booting needs multiple attempts mtndew 13 17,734 10-04-2020, 08:55 AM
  Upgrade eMMC card - boot problems alpopa 0 2,311 09-16-2020, 12:31 PM
Last Post: alpopa
  Reboot, and halt and boot, are not the same regivanx 0 1,975 09-14-2020, 02:20 PM
Last Post: regivanx
  PBP not booting screen blank after SD card boot Jakobp 10 13,909 08-18-2020, 08:56 PM
Last Post: trinapicot
  Manjaro 20.06 requires multiple boots from eMMC to launch successfully on PBP Spectre 0 2,246 07-09-2020, 06:12 PM
Last Post: Spectre
  Boot problems with new 128GB eMMC module Kareema 1 3,343 05-31-2020, 10:36 AM
Last Post: Kareema
