Impossible to minimize a window with Phosh
(08-16-2022, 08:56 PM)treebeard Wrote:
(08-16-2022, 03:07 PM)anonymous Wrote: Hello
Since the latest update today, I can't minimize a window in Phosh. It drives the Pinephone very difficult to use. I don't even know a shortcut to minimize the current window. The widget in the bottom no longer works Sad
Do you know a solution or a workaround?
Maybe connected to this?
Thank you for the suggestion. Actually, I've found the solution about an hour ago. Something seems to have been modified in the behavior of Phosh, you can no longer minimize the window by pressing the button in the bottom ^, you have to pull from the very bottom. Actually, it's much better now in my humble opinion, it avoids accidental presses which typically occurred when writing SMS in my case. Phosh is becoming more and more mature Smile
RE: Impossible to minimize a window with Phosh - by anonymous - 08-17-2022, 01:57 AM
  Auto start application on Phosh login Zebulon Walton 8 3,381 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Using sway along phosh fdlamotte 2 3,317 05-11-2023, 04:24 PM
Last Post: kabouik
Exclamation Impossible to login since the latest update anonymous 12 4,235 02-26-2023, 01:01 PM
Last Post: anonymous
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 1,792 02-24-2023, 12:11 AM
Last Post: nexion
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 8,842 10-14-2022, 05:38 PM
Last Post: Krafter
  Phosh 0.20 beta on mobian Anthony1224 1 1,632 06-11-2022, 06:29 AM
  Transparent Phosh App Grid? arno_nuehm 1 1,762 03-15-2022, 06:00 AM
Last Post: dante404
  Phosh modem on/off effectiveness? Zebulon Walton 0 984 01-24-2022, 09:21 AM
  Updating Phosh from Gitlab ragreenburg 2 2,346 10-07-2021, 08:35 AM
Last Post: ragreenburg
  Seems like Phosh is in downgrade mode... ryo 17 16,240 06-01-2021, 06:22 PM
Last Post: ryo
