SSH from Windows PC into PinePhone?
If everything's working and configured then you should just be able to run any X11 application and it will display on your Windows desktop rather than on the phone. Wayland applications will still display on the phone. For applications that can run on either there may be an option you can set to force it to use X11 but you'll probably have to look it up. If you want the application to run in the background so you can still do other things in the command line then stick ' &' on the end of the line. If you forget then you can use ctrl-z to pause the application, then 'bg' to resume it in the background. So for example to start libreoffice writer in the background it should look something like:
mobian@mobian:~$ libreoffice --writer &
[1] 2154
mobian@mobian:~$
The '[1] 2154' is telling you that the process id for the program that just started is 2154. After a few seconds the libreoffice splash screen appeared on my desktop, followed by the writer application window in phone aspect ratio (as that's where it was last started - it seems to remember the window size from the last time it ran). You can just resize the window as normal.
I'm assuming it should work the same on Windows as on linux, but I can't try it. There's a chance that the libreoffice detection thing will kick in like it did at one point with phosh, and that it's just ok for me because I'm using a common desktop environment that it recognises.
RE: SSH from Windows PC into PinePhone? - by wibble - 06-08-2022, 10:58 AM
  Pinephone won't boot. spha 13 3,289 05-15-2024, 10:31 PM
Last Post: Richy_T
  Pinephone boot. Richy_T 5 293 05-15-2024, 03:35 PM
Last Post: Richy_T
  eSIM on PinePhone just_a_q 4 2,822 05-14-2024, 01:35 PM
  PinePhone - boot from microSD laserpyramid 9 1,051 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 536 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 356 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 113,209 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 2,077 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 744 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,756 12-28-2023, 07:55 AM
Last Post: MTXP
