Image sizes too big for SD card?
#21
(07-19-2016, 12:24 PM)montero65 Wrote: So, lots of comments, but not much help in fixing the problem. I was originally hoping I could get a quick answer of "you need to format the card with this sector size and it will be good" or something simple.
To be honest, I do keep forgetting to try the formatting that Don suggested when I get home, and never remember to bring a card to work to try out. Has anyone tried what Don suggested, using the SD formatter program? Did it work out?
I decided to write a copy of the latest non-rooted android image, and, this time, ran into the issue of a 32 gb SD not being big enough to hold the 32 gb image.
While SDFormatter is definitely the formatting tool that I would recommend using, I don't believe this is a formatting issue. I'm in agreement its an issue of the image size bumping up against the actual SD card size.
I will, as always, defer to higher levels of expertise, but would seem like the easiest fix is for the images to be re-sized to fall below worst case SD card capacities for each image size increment.
Image sizes too big for SD card? - by montero65 - 07-07-2016, 09:12 AM
RE: Image sizes too big for SD card? - by DonFL - 07-07-2016, 10:18 AM
RE: Image sizes too big for SD card? - by Luke - 07-07-2016, 10:40 AM
RE: Image sizes too big for SD card? - by DonFL - 07-07-2016, 10:51 AM
RE: Image sizes too big for SD card? - by DonFL - 07-07-2016, 11:14 AM
RE: Image sizes too big for SD card? - by g_t_j - 07-14-2016, 03:57 PM
RE: Image sizes too big for SD card? - by gtpboy - 07-15-2016, 12:11 PM
RE: Image sizes too big for SD card? - by Pepe - 07-15-2016, 12:25 PM
RE: Image sizes too big for SD card? - by gtpboy - 07-16-2016, 12:59 PM
RE: Image sizes too big for SD card? - by jimwrey - 07-16-2016, 05:04 PM
RE: Image sizes too big for SD card? - by DonFL - 07-19-2016, 01:17 PM
RE: Image sizes too big for SD card? - by Ghost - 07-19-2016, 01:53 PM
RE: Image sizes too big for SD card? - by Boring - 07-20-2016, 09:15 AM
RE: Image sizes too big for SD card? - by Ghost - 07-21-2016, 09:08 PM
  Issues with SD Card and Running Android Twistedx 0 3,570 02-26-2019, 11:58 AM
Last Post: Twistedx
  Reducing Android Image download size. KPhillisJr 4 8,144 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 6,397 07-18-2017, 08:49 AM
Last Post: eclay
  Corrupt SD Card? CaptainCWA 13 17,066 06-04-2017, 08:01 PM
Last Post: pfeerick
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 23,271 05-05-2017, 01:50 AM
Last Post: Quezbeme
  Editing SD card simplexdan 2 4,032 02-25-2017, 12:09 PM
Last Post: simplexdan
  android image & sd card size problems tomarneson 11 17,873 01-24-2017, 05:31 AM
Last Post: ayufan
  Creating bootable SD card on Mac OS X colinj 13 20,457 01-24-2017, 03:03 AM
Last Post: MarkHaysHarris777
  SD card too small Error loungehound 7 12,709 01-21-2017, 05:37 PM
Last Post: Bluphire
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 24,054 10-29-2016, 04:31 AM
Last Post: joe
