RAW image output only 32MB and not working
adm1n@raspberrypi:~/Downloads $ sudo dd if=/dev/urandom of=/dev/mmcblk0 bs=8M
^C985+0 records in
985+0 records out
8262778880 bytes (8.3 GB, 7.7 GiB) copied, 610.237 s, 13.5 MB/s
adm1n@raspberrypi:~/Downloads $ ls
flash-it.sh  mmcblk0  sdb  u-boot-sunxi-with-spl-pinephone.bin
adm1n@raspberrypi:~/Downloads $ sudo su
root@raspberrypi:/home/adm1n/Downloads# bash flash-it.sh
Sailfish OS Pine64 device flasher V0.3.3
Which image do you want to flash?
1) PinePhone 1.0 (Development) device
2) PinePhone 1.1 (Brave Heart) or 1.2 (Community Editions) device
3) PineTab device
4) PineTab Dev device
5) Pinephone Pro
#? 2
Downloading images...
https://github.com/sailfish-on-dontbeevi...-pinephone
u-boot.zip        100%[=============================================================================================================================================================================================================================================================================================================================>]  3.56M  3.29MB/s    in 1.1s
u-boot-sunxi-with-spl-pinephone.bin        100%[=============================================================================================================================================================================================================================================================================================================================>] 740.57K  1.92MB/s    in 0.4s
pinephone-1.1-rootfs.zip        100%[=============================================================================================================================================================================================================================================================================================================================>] 399.95M  8.79MB/s    in 52s
Which SD card do you want to flash?  Exclamation here I want to choose eMMC
NAME    MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
sda      8:0    1 59.2G  0 disk
├─sda1    8:1    1  256M  0 part /boot
└─sda2    8:2    1 58.9G  0 part /
sdb      8:16  1 28.9G  0 disk
├─sdb1    8:17  1  122M  0 part
└─sdb2    8:18  1 28.8G  0 part
sdc      8:32  1  7.3G  0 disk
└─sdc1    8:33  1  49M  0 part
mmcblk0 179:0    0 14.8G  0 disk
raw
Device node (/dev/sdX): mmcblk0
Flashing image to: mmcblk0
WARNING: All data will be erased! You have been warned!
Some commands require root permissions, you might be asked to enter your sudo password.
Creating EXT4 file system...
Unmounting mmcblk0
umount: mmcblk0: not mounted.  Exclamation
32+0 records in
32+0 records out
33554432 bytes (34 MB, 32 MiB) copied, 2.10747 s, 15.9 MB/s
Error: The location 256MB is outside of the device /home/adm1n/Downloads/mmcblk0.
Error: The location 6250MB is outside of the device /home/adm1n/Downloads/mmcblk0.
mke2fs 1.46.2 (28-Feb-2021)
The file mmcblk0p1 does not exist and no size was specified.  Exclamation
The file mmcblk0p2 does not exist and no size was specified.
The file mmcblk0p3 does not exist and no size was specified.
Flashing U-boot...
Archive:  u-boot.zip
  inflating: u-boot-bootloader/pinephone-1.1/boot.scr
  inflating: u-boot-bootloader/devkit/boot.scr
  inflating: u-boot-bootloader/pinephone-pro/boot.scr
  inflating: u-boot-bootloader/u-boot/bl31_0x00040000.bin
  inflating: u-boot-bootloader/u-boot/u-boot.img
  inflating: u-boot-bootloader/u-boot/u-boot-dtb.img
  inflating: u-boot-bootloader/u-boot/spl/u-boot-spl.bin
  inflating: u-boot-bootloader/u-boot/spl/sunxi-spl.bin
  inflating: u-boot-bootloader/u-boot/spl/u-boot-spl-nodtb.bin
  inflating: u-boot-bootloader/u-boot/spl/u-boot-spl-dtb.bin
  inflating: u-boot-bootloader/u-boot/u-boot-dtb.bin
  inflating: u-boot-bootloader/u-boot/u-boot.bin
  inflating: u-boot-bootloader/u-boot/u-boot.itb
  inflating: u-boot-bootloader/u-boot/tools/binman/test/descriptor.bin
  inflating: u-boot-bootloader/u-boot/u-boot-sunxi-with-spl.fit.itb
  inflating: u-boot-bootloader/u-boot/u-boot-sunxi-with-spl.bin
  inflating: u-boot-bootloader/u-boot/u-boot-rockchip.bin
  inflating: u-boot-bootloader/u-boot/bl31_0xff3b0000.bin
  inflating: u-boot-bootloader/u-boot/idbloader.img
  inflating: u-boot-bootloader/u-boot/tpl/u-boot-tpl-nodtb.bin
  inflating: u-boot-bootloader/u-boot/tpl/u-boot-tpl-dtb.bin
  inflating: u-boot-bootloader/u-boot/tpl/u-boot-tpl.bin
  inflating: u-boot-bootloader/u-boot/tpl/u-boot-tpl-rockchip.bin
  inflating: u-boot-bootloader/u-boot/bl31_0xff8c0000.bin
  inflating: u-boot-bootloader/u-boot/u-boot-nodtb.bin
  inflating: u-boot-bootloader/pinephone-1.0/boot.scr
  inflating: u-boot-bootloader/arm-trusted-firmware/build/sun50i_a64/release/bl31.bin
  inflating: u-boot-bootloader/arm-trusted-firmware/build/rk3399/release/m0/rk3399m0.bin
  inflating: u-boot-bootloader/arm-trusted-firmware/build/rk3399/release/m0/rk3399m0pmu.bin
extracting: u-boot-bootloader/arm-trusted-firmware/plat/arm/board/common/protpk/arm_protpk_rsa_sha256.bin
extracting: u-boot-bootloader/arm-trusted-firmware/plat/arm/board/common/rotpk/arm_rotpk_ecdsa_sha256.bin
extracting: u-boot-bootloader/arm-trusted-firmware/plat/arm/board/common/rotpk/arm_rotpk_rsa_sha256.bin
  inflating: u-boot-bootloader/arm-trusted-firmware/plat/rockchip/rk3368/drivers/ddr/rk3368_ddr_reg_resume_V1.05.bin
  inflating: u-boot-bootloader/arm-trusted-firmware/plat/rockchip/rk3399/drivers/dp/hdcp.bin
  inflating: u-boot-bootloader/pinetab/boot.scr
92+1 records in
92+1 records out
758339 bytes (758 kB, 741 KiB) copied, 0.0569735 s, 13.3 MB/s
Flashing rootFS...
Archive:  pinephone-1.1-rootfs.zip
  inflating: pinephone-1.1/sfe-pinephone-1.1-4.3.0.12-devel-20220501/Jolla-4.3.0.12-pinephone-1.1-aarch64.ks
  inflating: pinephone-1.1/sfe-pinephone-1.1-4.3.0.12-devel-20220501/Jolla-4.3.0.12-pinephone-1.1-aarch64.packages
  inflating: pinephone-1.1/sfe-pinephone-1.1-4.3.0.12-devel-20220501/Jolla-4.3.0.12-pinephone-1.1-aarch64.urls
  inflating: pinephone-1.1/sfe-pinephone-1.1-4.3.0.12-devel-20220501/sfe-pinephone-1.1-4.3.0.12-devel-20220501.tar.bz2
mount: /home/adm1n/Downloads/root: special device mmcblk0p2 does not exist.  Exclamation
Copying kernel to boot partition...
mount: /home/adm1n/Downloads/boot: special device mmcblk0p1 does not exist.
Boot partition mount: ./boot
allwinner Image sun50i-a64-pinephone-1.0.dtb sun50i-a64-pinephone-1.1.dtb sun50i-a64-pinephone-1.2.dtb sun50i-a64-pinetab-dev.dtb sun50i-a64-pinetab.dtb
Are you installing to an SD card? y
Clear root password? y
Cleaning up!
Unmounting mmcblk0
Flashing mmcblk0 OK!
You may now remove the SD card and insert it in your Pine64 device!
root@raspberrypi:/home/adm1n/Downloads# exit
exit
RE: RAW image output only 32MB and not working - by Kimberley van Buyten - 05-30-2022, 01:40 AM
  Script not working Andidoko 4 1,611 04-09-2023, 12:03 PM
Last Post: moodroid
  flash-it.sh script currently unable to create a SailfishOS image acrux 3 3,617 07-23-2021, 01:06 AM
Last Post: OhneZ
  February image, upgrade to SFOS4 defactofactotum 8 7,837 02-24-2021, 09:45 AM
Last Post: defactofactotum
  January image defactofactotum 8 9,341 01-08-2021, 10:27 PM
Last Post: DrPhibes
  December image defactofactotum 3 5,081 12-16-2020, 05:35 AM
  Fresh image, SIM card working RodneyMyers 22 22,436 09-23-2020, 08:53 AM
Last Post: sfb
