Flashing gone wrong
(05-24-2022, 02:53 PM)erg Wrote:
(05-24-2022, 01:54 PM)fxc Wrote:
(05-24-2022, 07:15 AM)erg Wrote: I broke stuff.
Booted from JumpDrive, saw what looked like two partitions (I guess they're actually separate emmc drives?) exposed (apart from the SD card), in frenzy formatted the first one to vfat, flashed system to the second partition with dd.
Pinephone doesn't start. I guess the first partition is a boot partition and I broke it. I can't find files that should go onto the first partition in order to fix it.
What should I do? Confused
Jumpdrive exposes the eMMC and the microSD card directly, which is probably what you saw in the "lsblk" output. Please don't format the drives manually, as that doesn't make sense and will just cause you issues: formatting a drive does not remove U-Boot from the partition so the phone will still load U-Boot and don't find a valid system (= the phone's screen stays black). I guess that is also where your other issues also originate from. When flashing an image it will contain everything you need, including the whole partition structure. Make sure you're flashing the partition to the whole disk, not to partition 1. The whole disk will typically be called ""sda", "sdb" or "sdc", not "sda1". The "1" next to "sda" means it is the first partition.
I did try that at first, flashing to /dev/sdc, only it failed with: No space left on the device. That's when I tried other options.
Was the issue solved or is there still an issue writing to the eMMC? If the latter I would suggest you to post the full "lsblk" output here.
Flashing gone wrong - by erg - 05-24-2022, 07:15 AM
RE: Flashing gone wrong - by wibble - 05-24-2022, 07:49 AM
RE: Flashing gone wrong - by erg - 05-24-2022, 08:05 AM
RE: Flashing gone wrong - by fxc - 05-24-2022, 01:54 PM
RE: Flashing gone wrong - by erg - 05-24-2022, 02:53 PM
RE: Flashing gone wrong - by fxc - 05-26-2022, 05:30 AM
RE: Flashing gone wrong - by erg - 05-26-2022, 05:49 AM
RE: Flashing gone wrong - by mikehenson - 05-26-2022, 07:06 AM
RE: Flashing gone wrong - by erg - 05-26-2022, 07:18 AM
RE: Flashing gone wrong - by fxc - 05-28-2022, 10:52 AM
  SD Card has wrong capacity AndyM 11 2,406 06-11-2023, 12:30 AM
Last Post: AndyM
  trouble flashing eMMC TylerBlackberry 3 1,246 04-13-2023, 05:55 AM
  Boot problem: wrong screen orientation Jetpac 6 3,809 07-18-2022, 12:47 PM
Last Post: fravoi
  Wrong PIN error lordearl 3 4,291 09-20-2021, 03:19 AM
Last Post: mcdanielmark473
  After flashing UT on eMMC Convergence package not working anymore dfjdw8 0 1,561 06-11-2021, 12:28 AM
Last Post: dfjdw8
  Wrong language installed on PINE64 mobian edition Derek7 0 1,994 04-02-2021, 05:25 PM
Last Post: Derek7
  Trying to diagnose what's wrong... m16a1 6 5,500 02-24-2021, 08:45 PM
Last Post: C0ffeeFreak
  Flashing SC card for Ubuntu Touch thorensjubilee 2 3,538 12-15-2020, 07:38 AM
Last Post: thorensjubilee
  Flashing an SD card using Pinebook Pro? Konsole? SanjevR 5 5,006 12-08-2020, 02:58 PM
Last Post: hiimtye
  Wrong information in FAQ jbit 1 2,615 07-16-2020, 02:40 PM
Last Post: wibble
