Pine A64 not powering up / Power button missing
(07-05-2016, 12:16 AM)janeku Wrote: 2. Regarding power button , there is also issue: It is not functional if you use it without battery. Your device will power on for a short and then power off. You need connected battery with some operational status (full, half full, etc) in order when you press power button your system could turn on. So, my recomendation is no to bother with it till something is figured out how to fix this issue. Just shut down your OS, unplug power supply and turn it on when you want it again.
Regards,
I've experienced this with a linux boot, but not android or remix. Power button works fine with android/remix, to boot or shutdown, no battery attached. I don't have a battery as yet, so not sure if that takes care of the linux issue and being able to use the power button to initiate boot.
Power button is also functional for powering down with debian and debian mate (https://www.pine64.pro/downloads/) which I tried for the first time last evening. (Based on first impressions, it may very well become my go-to debian image.). a quick press gives shutdown options..reboot or shutdown.
Anyone else seeing power button problems when a battery is not attached? I just might be misunderstanding the scenario janeku is describing.
RE: Pine A64 not powering up / Power button missing - by DonFL - 07-05-2016, 06:09 AM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,657 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 628 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 4,010 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 6,029 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 3,373 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 4,537 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 7,838 12-06-2020, 03:53 PM
Last Post: junkyj753
  Pine64+ power button PaddyChan 0 2,807 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Node Red on the Pine DonFL 0 2,797 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 3,263 12-02-2019, 09:36 PM
Last Post: netHolio
