User login change
(04-02-2022, 02:28 PM)usagi Wrote:
(04-02-2022, 11:13 AM)onubatux Wrote: I have created the user and installed lightdm, without problems. But it is not functional because you need a keyboard to be able to write the username and password.
does anyone know how to invoke the mobian on-screen keyboard for lightdm? with that it would work.
Sorry but I don't speak English, I use a translator.
How did you install it and configured it? When using the https://wiki.debian.org/LightDM instructions when rebooting I only get a blank screen.
use the command: sudo apt install lightdm It installed without problems, I restarted the phone and started with lightdm the same one from pc, but that is not functional you need one that invokes the on-screen keyboard
User login change - by usagi - 03-30-2022, 03:24 PM
RE: User login change - by wibble - 03-31-2022, 09:42 AM
RE: User login change - by usagi - 04-01-2022, 03:57 PM
RE: User login change - by wibble - 04-02-2022, 10:06 AM
RE: User login change - by onubatux - 04-02-2022, 11:13 AM
RE: User login change - by fxc - 04-02-2022, 11:32 AM
RE: User login change - by usagi - 04-02-2022, 02:28 PM
RE: User login change - by onubatux - 04-02-2022, 11:35 PM
RE: User login change - by wibble - 04-03-2022, 09:43 AM
RE: User login change - by onubatux - 04-04-2022, 12:49 PM
RE: User login change - by johnpine - 05-13-2022, 01:16 AM
RE: User login change - by usagi - 04-08-2022, 02:51 PM
  Auto start application on Phosh login Zebulon Walton 8 10,257 10-14-2023, 06:29 AM
Last Post: alaraajavamma
Exclamation Impossible to login since the latest update anonymous 12 13,263 02-26-2023, 01:01 PM
Last Post: anonymous
  Change GUI from Phost to Gnome (or anything else) johnpine 0 1,880 05-27-2022, 06:52 AM
Last Post: johnpine
  How to do automatic login or shorten the login number amosbatto 0 2,137 12-08-2021, 09:29 PM
Last Post: amosbatto
  GDM3 Receiving call on login screen d-.-b 4 7,081 10-07-2021, 06:59 PM
Last Post: d-.-b
  Change default program for a file type 3x5co 1 3,287 09-01-2021, 05:26 PM
  Change locking of Ctrl modifier? vandys 1 3,031 05-08-2021, 02:46 AM
Last Post: MtnSk8
  Debian / mobian Pine64 - User Manual? Harry27 1 5,139 03-03-2021, 04:50 PM
Last Post: LibrePhoneUser
  How to change the minimum password length when changing from default passwords arturo2bodegas 3 7,573 07-18-2020, 01:51 PM
Last Post: arturo2bodegas
  power management change? pjsf 1 5,148 06-05-2020, 05:16 PM
Last Post: a-wai
