no boot white led flashing
(03-27-2022, 07:36 AM)moserwi Wrote: debian bullseye
setup: 32Gb SD-Card for the debian-installer
32 GB emmc for the OS
tried the official debian iso via usb-stick. The problem is known since 2020. The iso wants to boot with grub and this - of course - fails due to EFI.
OK did the debian-installer on SD-Card and installed on emmc.
Result: rockpro is not booting any more and the white led is flashing.
Recloned the debian-installer on the sd-card again ... same result
removed the emmc - same result
inserted the previously working armbian emmc - same result.
I am confused!
Futhermore, the rockpro64 wiki did not feed me with informations about the default LED-Status.
Thanks for input...
Just write the Debian Bullseye image directly to SD card and try booting. For the moment forget about eMMC. If that doesn't work try one of the Armbian images which you can find here https://armbian.hosthatch.com/archive/ro...4/archive/
no boot white led flashing - by moserwi - 03-27-2022, 07:36 AM
RE: no boot white led flashing - by Rocklobster - 03-27-2022, 06:14 PM
RE: no boot white led flashing - by moserwi - 03-28-2022, 02:19 PM
RE: no boot white led flashing - by Rocklobster - 03-28-2022, 07:26 PM
RE: no boot white led flashing - by mlohdael - 03-26-2023, 08:11 AM
RE: no boot white led flashing - by RocknKiosks - 04-27-2023, 05:23 PM
RE: no boot white led flashing - by RocknKiosks - 04-29-2023, 07:38 PM
RE: no boot white led flashing - by wdt - 05-18-2023, 10:46 AM
  enble boot after power loss/restore dkebler 18 9,582 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 120,535 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 683 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,298 07-14-2023, 08:59 AM
Last Post: rockjonn
  u-boot locked on pine64pro ljones 1 1,568 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,321 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,161 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,826 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,171 06-09-2022, 10:56 AM
Last Post: pspgarret
  RockPro64 has no white led, nor will it boot past... AnjinMeili 2 1,998 05-31-2022, 09:19 AM
Last Post: Rocklobster
