PP Keyboard - Top Row Actuation
(03-14-2022, 06:26 AM)wibble Wrote: Thanks, nice detailed post. I would hit the Rate button, but I guess it doesn't appear until you've made a few more posts.
It looks like they were using 3d printing for rapid pattern making, so might be able to revise things for the next production run.
I'm glad it's appreciated. I was a bit worried about posting on a topic that was already stickied and closed.
I hope they are able to apply a fix at the factory. From a DIY fix perspective, adding tape or removing material are pretty quick and easy fixes. Solution 1 should only take a few minutes, and solution 2 took me around 30 minutes. Doing these things in a factory environment might be more complicated because they require a human touch and extra QA.
I would be surprised if they were using 3D printing for a large production run like this. My guess is the marks under the key cap are tool marks from when the molds were machined. Removing material from the keycap would require adding material to the mold, which I think means having to mill a new section of mold. I think it's probably less costly to source some adhesive mylar spacers to be added at the factory during assembly. Then again, I don't have experience with injection molding in a factory environment, and the change might be easier to make than I think.
Here's an additional thought to adding spacers: potential interference with the phone screen. My PP 1.2 has the glass screen protector and it already touches the keycaps when the keyboard is closed. The PPP is slightly thicker, so with the screen protector, the situation may be even worse. Adding shims under the keycaps makes them stick up higher and could have some long-term negative consequences for both screen and keyboard membrane. Maybe this concern is completely overblown, I don't know.
RE: PP Keyboard - Top Row Actuation - by wibble - 03-14-2022, 06:26 AM
RE: PP Keyboard - Top Row Actuation - by johnnycontrario - 03-14-2022, 09:47 AM
RE: PP Keyboard - Top Row Actuation - by tllim - 03-14-2022, 11:18 PM
RE: PP Keyboard - Top Row Actuation - by wibble - 03-17-2022, 03:53 AM
RE: PP Keyboard - Top Row Actuation - by jurop88 - 03-15-2022, 10:54 AM
RE: PP Keyboard - Top Row Actuation - by TRS-80 - 04-30-2022, 04:58 PM
RE: PP Keyboard - Top Row Actuation - by tllim - 05-03-2022, 08:55 PM
RE: PP Keyboard - Top Row Actuation - by TRS-80 - 05-15-2022, 03:40 PM
  keyboard case charging but not typing new2pinephone 18 5,992 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 10,522 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 455 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,279 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 479 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,293 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 548 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 646 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,064 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 877 10-11-2023, 09:03 AM
Last Post: elof
